Looking for rear drop only
RE: Looking for rear drop only
OK...my local ford shop said they figure about 2-3 hours labor for the rear springs...which will cost me $200-225. Does that sound right...again, just for the rears?? Can anyone tell me what they've spent for this install??
Thanks
Thanks
Mr. Mustang...looks like you have a chin spoiler...any clearance issues??
Dear 05Vert,
NO-NO-NO!!!
Do not have the dealership install your spings because they charge way too much $$$..
I live in Chicago where everything is priced higher and had my local muffler shop install the rear springs, an adjustable panhard brace and alignment the rear axle for $75.00 (OUT THE DOOR)...
Your dealer has a labor rate of probably about $75 - $90 per hour...
OUCH!!!
Go to a Midas, Merlins, Speedy, etc and talk to the guys there... They will take care of your for less money...
Best of Luck, and post pictures of your car afterwards... Dave
NO-NO-NO!!!
OUCH!!!
One question i have is after awhile the springs settle in and drop a little more with some miles on them, has anyone found a problem with the rear settling lower then the front?
05vert: I changed my rear springs myself.Took me 30 minutes.It's VERY easy. If a dealer or anyone else quotes you 2-3 hours they are strokin' you.The only thing you unbolt is the 2 bolts for your shocks.Lower the rearend with a floor jack(after the car is on jack stands!) after the bolts are out and bingo....pull each spring out,in goes the new ones ,jack-up the rear ,put your shock bolts in, and your done. A very easy mod that pays off big-time.
ORIGINAL: 05vert
Ok...here is a befoe and after, the agnles are close, but not exact, sorry. This is with just the Roush rear springs...nothing more. I think it looks much better!!
