Help!..X pipe install
Old Sep 17, 2012 | 02:10 PM
robred81's Avatar
robred81
Default Help!..X pipe install
Started installing my off road x pipe today. Got the first three bolts off no problem. The dreaded top passenger side nut is loose but has now gotten about 3 threads from being off and now just spins without going anywhere. Anyone have any suggestions, I've tried putting pressure on the bolt but it still just spins.
Old Sep 17, 2012 | 02:15 PM
TRexGAWD's Avatar
TRexGAWD
You're talking about where the stock mid connects to the header?.. Have you tried feeling behind it to see if something is spinning back there? I can't remember what it looks like exactly, but I think you can put a wrench on both sides...
Old Sep 17, 2012 | 02:17 PM
Milspec's Avatar
Milspec
So you've actually gotten the top passenger nut almost all the way off (three threads), and now the nut is spinning on the stud but not moving??
Did you take the battery and battery crate out to unplug the passenger o2?...When I did mine I took those out and could get a better view of the stud from the topside.
It sounds odd that it would be almost all the way off and just spinning....I guess it could be stripped, but just seems odd...what does it look like?
Old Sep 17, 2012 | 02:20 PM
robred81's Avatar
robred81
It's where the converter and manifold meet. Their isn't anything behind it to spin, just a nut on the stud. It's so frustrating because its so close to being off the just spins on the stud, it will tighten up but will not come all the way off.
Old Sep 17, 2012 | 02:21 PM
robred81's Avatar
robred81
I did remove the batter so i could see it better so i know the stud isn't moving.
Old Sep 17, 2012 | 02:22 PM
Milspec's Avatar
Milspec
There could be something on the last few threads preventing the bolt from moving further...Do you have any PB Blaster or penetrating oil...if so I'd recommend soaking the whole stud and nut area and let it set in then try again...
Old Sep 17, 2012 | 02:38 PM
robred81's Avatar
robred81
tried the PB Blaster, the nut is pretty rough looking from trying to get it broke loose. At a loss right now, not sure what to try next.
Old Sep 17, 2012 | 02:40 PM
Milspec's Avatar
Milspec
Check the inside of your socket and the flat edges of the nut, does it appear that the nut edges have been rounded a bit, OR the inside of the socket is worn down?
Old Sep 17, 2012 | 02:43 PM
robred81's Avatar
robred81
nut is rounded a bit but its loose enough I can spin it with my fingers, just doesn't go anywhere.
Old Sep 17, 2012 | 02:45 PM
Milspec's Avatar
Milspec
Sh*t, that's a new one for me....so if you tighten it, can you see anything jacked up with the threads on the one part of the stud where it will start spinning?
