more problems....
Old Sep 28, 2012 | 02:24 PM
sharony1994's Avatar
sharony1994
Default more problems....
so i just took my car to the mechanic and i need to bleed my clutch and i have no idea what that means. also my back left wheel when rolling makes a squeaky sound and he doesn't no what is wrong with it yet. i had my dad take a look at it and he said as i was driving the wheel would wiggle a little any ideas?
i also recently put a grand into replacing my clutch a month ago and it already needs work.
if any 1 has had the same issues please let me know what i have to do thanks.
05gt
Old Sep 28, 2012 | 02:35 PM
kevinmalec's Avatar
kevinmalec
I am familiar with bleeding the brakes, which I assume is very similar to bleeding the clutch. Typically, if there are any air bubbles in the hydraulic/brake lines, the mechanic will need to bleed the lines to get rid the air bubbles.
Are all of your lug nuts tightened down?
Does the wheel or axle looked damaged?
Old Sep 28, 2012 | 02:37 PM
sharony1994
i have no clue if either are damaged im pretty sure they are tightened but ill go check and make sure.
thanks for the info
Old Sep 28, 2012 | 03:06 PM
sharony1994
Thank you so much it ended up being that the wheel was loose i feel very stupid for not checking that first appreciate the help.
Old Sep 28, 2012 | 03:09 PM
kevinmalec's Avatar
kevinmalec
No problem! Glad it was an easy fix. ;-)
Old Sep 28, 2012 | 05:03 PM
baddog671's Avatar
baddog671
Who had the wheel off last?
Old Sep 28, 2012 | 08:15 PM
sharony1994
no clue haven't touched the back wheels since i got the car.
Old Sep 28, 2012 | 08:20 PM
BleedinBlue's Avatar
BleedinBlue
Holy crap that could have been BAD!
Old Sep 28, 2012 | 08:35 PM
AK_Kayaker's Avatar
AK_Kayaker
And if you just had the clutch replaced a month ago, the mechanic that did it needs to bleed it for free, as they should have checked it then.
Old Sep 28, 2012 | 09:46 PM
Art161's Avatar
Art161
It's a good idea to check the wheel lug nuts every 500 miles. You don't need to torque them for the check. Just use a regular lug nut wrench to make sure the lug nuts are snug.
