Front Brake Issue..
Old Sep 29, 2012 | 01:24 PM
SLVRSTNG06's Avatar
SLVRSTNG06
Default Front Brake Issue..
Did a front brake job about a month ago, loud popping noise when I let off the brake with the wheel turned. Also, the driver side rotor has a strange "wear" pattern, as shown in the pics. Thinking the caliper is sticking, but really not sure whats going on.
Attached Thumbnails Front Brake Issue..-photo.jpg   Front Brake Issue..-photo-1-.jpg
Old Sep 30, 2012 | 12:16 AM
JThor's Avatar
JThor
The parts didn't get back in straight. I'm pretty sure what you are seeing is that the pad is only contacting part of the rotor.
Check your work. Make sure all the parts are there and any retaining springs are properly installed.
Old Oct 1, 2012 | 02:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
+1, the outer rotor is getting all of the contact. The inner rotor still has hatch marks (like when new out of the box).
Something didn't get put back in correctly.
A sticking caliper would give you a continuous metallic scraping sound at low speeds and your car would in some cases pull to that side as well.
Old Oct 1, 2012 | 04:30 PM
SLVRSTNG06's Avatar
SLVRSTNG06
took the brake pads out and reset the calipers, hopefully it did the trick ill check the wear on the rotor again in a few days.
Oct 7, 2015 07:02 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
