Sponsored by:
Sponsored by:
Still burning oil and I have 10K miles now
Old 10-07-2012, 08:04 AM
99gtstang
99gtstang's Avatar
Default Still burning oil and I have 10K miles now
I did the first oil change at 4K with Ford filter and lube. Now I have 10K and have added almost 1 qt. Is that normal? Added half qt in last 3000 miles.
I plan to change soon since the indicator reflects about 38% left. I am going with OE filter and RP.
Plan to get a separator, but it won't save that much oil.
99gtstang is offline
Old 10-07-2012, 09:49 AM
Nuke
Nuke's Avatar
If you're having to add oil, I'm not sure I'd go with a synthetic at this time. I'd continue to use a blend until you determine if the fluid loss isn't decreasiing. Ford will tell you that's normal but I've had more cars than people have toes and only one used oil and that was after 200,000 miles.
I'll assume it's not a leak. Are you doing a lot of short distance driving (less than 10 miles one way)?
Nuke is offline
Old 10-07-2012, 09:57 AM
moosestang
moosestang's Avatar
My wifes Chrysler uses 1/2 quart every 1,000 miles, so stop bitchin! Chrysler considers 1 quart every 1,000 miles to be acceptable!
Don't buy any Chrysler/dodge product with the 3.5L v6, because it is a POS of an engine.
So almost a 1.5 quarts in 6,000 miles? That could all be going through your pcv valve depending on how it was driven.
moosestang is offline
Old 10-07-2012, 10:07 AM
99gtstang
99gtstang's Avatar
Interesting - why would you wait on the synthetic oil? Other than figure out the consumption. Maybe I should research more about semi-full before swapping.
No leaks
1 to 2 a day max <10 miles.
Old 10-07-2012, 10:12 AM
99gtstang
99gtstang's Avatar
Don't buy any Chrysler/dodge product with the 3.5L v6, because it is a POS of an engine. <- Quit bitching - HAHA
I need to invest in a catch can right away and keep a close eye on the consumption.
My wife, my insurance agent will never allow a dodge product in our household. They total out to easy upon impact and minor damage generally will cost more to repair.
Old 10-07-2012, 10:26 AM
P Zero
P Zero's Avatar
When breaking an engine in, it's best to use regular oil.
Run dino oil for the first 1k miles. Ideally though, you'd do this:
oil change @ 100 miles. then 500 miles, then 1k miles. (changing filters with each oil change.)
This insures that all of the metal shavings get out of the system and that all of the parts have broken in properly.
It's not a good idea to use synthetic for the break in period because it's too slippery.
P Zero is offline
Old 10-07-2012, 10:28 AM
99gtstang
99gtstang's Avatar
Makes enough sense! I will run another round of semi before the switch and keep a close eye on the consumption.
Thanks for all the replies.
Old 10-07-2012, 11:57 AM
Nuke
Nuke's Avatar
Those less-than-10-miles-per-trip are a killer on an engine. It's possible that after shutting the engine off before everything has properly expanded that the engine is bypassing some oil and blowing it out the next startup and since each of your startups are short distance...
Nuke is offline
Old 10-07-2012, 12:02 PM
99gtstang
99gtstang's Avatar
I'll start driving her car
Lunch for work is a daily short trip, but yesterday I made 2 <6 miles trips to get breakfast then dinner.
Thanks for the input. I am going to tightening down a little on my short trips.
Old 10-07-2012, 02:50 PM
moosestang
moosestang's Avatar
Try using 5w30 next time, assuming you are using 5w20. I still think 5w20 is too thin for these high strung 5.0's.
I just put rotella T 10w30 in the wifes car. I will probably try a 15w40 diesel after that if it doesn't slow down the consumption.
Her car has over 70k miles, but that still unacceptable to me.
Quick Reply: Still burning oil and I have 10K miles now
