Dash lights and turn lights still on after car is turned off?
[Solved] water leaking passenger side
your cowl drains are plugged. there are 2. the pass side one is between the battery and engine on the firewall about half way down. the drivers side one is in same relative area. pull them out and clean them, likely plugged with leaves. the cowl space fills up and water pours into the cabin thru the cabin filter opening. the water runs over the SJB and caused all kinds of electrical issues. youll likely need to remove the SJB, clean all the connectors and reinstall. good luck
Same problem and root cause
I have the same problem. Went through a car wash. Figured out the coal drain was clogged after the second time it happened. I have cleaned the SJB with electronic cleaner twice with no results. Battery still has a constant drain due to button/**** illumination lights staying on. Ang ideas on how to fix?
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
