ran low oil
Old Oct 14, 2012 | 09:19 AM
clix813's Avatar
clix813
Default ran low oil
So i changed my oil and since i dont have a manual and didnt take 2 seconds to use google i asked the autozone guy how much oil my car took. He told me 5 qts. I believed him sinces thats how much my 2002 gt took. It red fine when i checked the dip stick anyways. So about 500 miles later i check it again and its barely on the min mark. I add a quart and now its fine. But do you guys think any damage was done.
Old Oct 14, 2012 | 09:24 AM
07grabber4.0's Avatar
07grabber4.0
Your fine
Old Oct 14, 2012 | 09:26 AM
Nuke's Avatar
Nuke
6 qts with a filter change.
PM me with your email addy and I'll send you a pdf of the OM.
Old Oct 14, 2012 | 11:03 AM
siggyfreud's Avatar
siggyfreud
Wouldn't sweat it OP. Lesson learned and the car should be fine.
Old Oct 14, 2012 | 02:18 PM
Art161's Avatar
Art161
Yes, you're fine for now. My concern is why the reading on the dipstick read okay right after the change, but 500 miles later it's reading about one quart down.
Perhaps you didn't wait long enough for the oil to drain into the pan when you changed the oil. If that's the case, then you're good. If you really did burn about one quart in 500 miles, then there could be an issue.
Check the dipstick frequently until you determine what, if anything, is going on. My guess is you didn't let the oil drain into the pan, but check the dipstick to be sure.
Edit: I messed up with my reasoning. Perhaps the filter wasn't full when you checked the oil after changing it. That would give you a good reading on the dipstick, but when the filter got full, the dipstick would read low.
Old Oct 14, 2012 | 04:03 PM
Nuke's Avatar
Nuke
Email sent with the OM attached.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
StalkerGT
Sep 25, 2015 02:41 PM
ctgreddy
Sep 20, 2015 08:35 PM
MusicCity615
Sep 12, 2015 07:05 AM
dalefrancis88
Sep 11, 2015 07:15 AM
