SYNC Problem - Resolution
Old Oct 26, 2012 | 09:49 AM
rogan01's Avatar
rogan01
Default SYNC Problem - Resolution
2012 GT Premium - SYNC died yesterday. Use it a lot for bluetooth/phone/ and playing music from usb port on thumb drive. All other radio functions worked. Called SYNC support and they gave me troubleshooting steps to follow for "reset" and said if they didn't work, would need to take to dealer. Went to car followed steps and they did not work at first. Step 1 was to press the "Phone" icon on the steering wheel and then scroll until I found option they said I should find. Pressing the button once did nothing. Pressed it/held down a few more times and SYNC came back on without doing anything else - had been completely dead on my ride home, turned car on/off, pressed all buttons, etc.
Just FYI - in case this helps anyone as I was going to post on here for help if this did not work.
Wondering - Anyone else had to do this or take to dealer for it? Just wondering how common this was (I looked through the SYNC owners manual troubleshooting section but there was nothing in there about it just going out completely)
Old Oct 26, 2012 | 10:53 AM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Originally Posted by rogan01
2012 GT Premium - SYNC died yesterday. Use it a lot for bluetooth/phone/ and playing music from usb port on thumb drive. All other radio functions worked. Called SYNC support and they gave me troubleshooting steps to follow for "reset" and said if they didn't work, would need to take to dealer. Went to car followed steps and they did not work at first. Step 1 was to press the "Phone" icon on the steering wheel and then scroll until I found option they said I should find. Pressing the button once did nothing. Pressed it/held down a few more times and SYNC came back on without doing anything else - had been completely dead on my ride home, turned car on/off, pressed all buttons, etc. Just FYI - in case this helps anyone as I was going to post on here for help if this did not work.
Hi, rogan01 -
To clarify, what issue were you experiencing? Were you not getting a response when pressing the voice command button? If so, the first line of troubleshooting would be resetting the system as per SYNC support. Instructions for both systems are below.
Standard radio:
http://Support.Ford.com/sync-technol...ter-reset-sync
Navigation:
http://Support.Ford.com/sync-technol...ync-navigation
If that doesn't help and you're comfortable will pulling the fuse for SYNC, I recommend saving yourself a trip to the dealer. The fuse panel for your vehicle is located in the lower passenger side area behind the kick panel. Open the trim panel door and remove the fuse cover for access. There will be a fuse pulling tool provided to the left the fuses and relays. The fuse for SYNC is in location 3 and needs to be left out for 3 minutes with the vehicle off.
If you're not comfortable doing this, you dealer can definitely take care of it for you. Let me know what you decide.
Jaclyn
Old Oct 26, 2012 | 08:30 PM
rogan01's Avatar
rogan01
SYNC was completely out (standard Shaker 500) - No bluetooth icon in display or connection to blackberry phone. Pressing AUX would result in FM/AM reception only - usb device installed in port but not being read. Pressing Voice Command button did not produce any response - i.e., "Please say a command".
Just FYI - Instructions provided by SYNC support were different than those in the link. I was told to press the "Phone icon" on the steering wheel (verbally by the support person - maybe there was a miscommunication on one or both sides) and then use the scroll buttons on the wheel to reach System Reset option. This did not work but I repeatedly pressed the Phone button (and held own for about 5 seconds) and SYNC came back on.
No mention was made of the fuse reset - so thank you for that step/option. If it happens again I will try the process described in the link.
Just wondering
1. what could have caused this,
2. how common it is and
3. if I can expect it to happen again. Never had this problem in 16 months I owned a 2011 GT Premium so curious as to possible causes and frequency of occurrence.
Thanks for the follow up support.
Originally Posted by FordIVTteam
Hi, rogan01 -
Standard radio:
Navigation:
Jaclyn
Old Oct 29, 2012 | 01:33 PM
FordIVTteam
Official Ford Rep
Just wondering
You're welcome, rogan01. I'm first level troubleshooting so I can't speculate on what would have caused this and my department doesn't track that information. However, if the issue persists, please let me know.
Jaclyn
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
yourmom6990
Sep 14, 2015 10:52 PM
