M90 Intercooler Pump Issue
Old Nov 16, 2012 | 04:34 PM
moosestang's Avatar
moosestang
since this thread is still going, i made a short video of my intercooler reservoir. I think the pump whipple uses is the same bosch pump that's stock on the gt500. This is with the afco dual pass heat exchanger installed.
http://www.youtube.com/watch?v=G797r...ature=youtu.be
Old Nov 17, 2012 | 07:54 PM
kenthicken's Avatar
kenthicken
Thanks moose. That pump flows a lot more fluid than the Roush / Bosch pump on my 427.
Old Nov 18, 2012 | 10:44 AM
moosestang's Avatar
moosestang
And that's without the motor running. It will flow more with more voltage.
The whipple reservoir is pretty small, same one used in 03-04 cobras, so that may make it look like it's flowing more.
I'm not sure how adding the afco heat exchanger affected flow, but the pump runs quieter now.
Old Apr 8, 2017 | 11:09 AM
Carlos Parra's Avatar
Carlos Parra
I've been having some intermittent intercooler pump noise on my M90 supercharged Mustang. Every now any again, it would buzz noticeably, and then reset when I turned the car off. I took to the dealership a while ago, and of course, they were unable to replicate the problem, so they did not replace the pump.
The other morning, I noticed the pump again, but a lower buzzing. So, I decided to look more deeply into the issue on the forums, read about some ways to test it, and found the following on my car:
1) Looked into the intercooler reservoir with the car running, and there is no "turbulence."
2) Drove the car an hour into work, left the car running, and looked again and no "turbulence."
3) Stuck my finger into the reservoir, and the coolant was warm (finger test says about 120 degrees or so).
My understanding is the pump should always be on, so I should always see turbulence.
I think the pump may be out, or working intermittently. Not sure about the coolant temp... it may supposed to be around 120 (cooler than the engine coolant), but I'm not 100% sure.
Any help here?
hey there im kind of in the same situation.. with the intercooler pump. any links on where to find one have the same m90 roush kit
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
