random misfires
Old Nov 27, 2012 | 01:35 AM
dray06GT's Avatar
dray06GT
Default random misfires
Noticed a slight skip at idle or when cruising at low rpm, codes for 1&8 misfired so we changed the plugs.. Now it says random misfires. Mechanic at ford dealership says this is from using champion plugs.. Only does this at idle .. Revs up fine..Anyone heard this or any suggestions?
Old Nov 27, 2012 | 02:31 AM
petrock's Avatar
petrock
If the plugs are the correct heat range for your motor & gapped correctly, the plugs wouldn't cause a misfire. If Champion's web site matches the plug part number you installed with your motor, and you gapped it correctly, then the plugs are probably not the cause.
Random misfires usually indicate a system wide problem, like a vacuum leak, low fuel pressure, low battery, bad alternator... The list goes on. Here is a good site on how to diagnose it: http://www.random-misfire.com and http://www.obd-codes.com/p0300
Old Nov 27, 2012 | 07:21 PM
Nuke's Avatar
Nuke
Any chance you have aftermarket COPs? They're known for problems.
Pr0cl1v1ty
Oct 11, 2015 03:08 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
ChampInSD
Oct 2, 2015 04:55 AM
jstrothe
Sep 24, 2015 12:17 PM
bconboy
Sep 21, 2015 12:52 PM
