Methanol System on Roush TVS2300 S/C?
Hi, I put in a lot of work hours 2012 so I'm expecting a decent sized tax return. After a lot of research, I think a methanol system is what I want to spend it on. It seems like a fairly simple system, I just have a few questions.
I want to mount a decent sized tank and run it from the trunk, would it be better to find some kind of aluminum tank to keep the methanol mix as cool as possible? Where can I find something like that
I have a Moroso catch can, so would spraying methanol in turn be running into it from the S/C manifold and does it matter?
It seems like a sweet deal if it's set up properly, but are there any high risks that it produces?
Also, can you recommend who I should buy it from.
Thank you! I'll post all the results
Make sure you have a qualified tuner who knows what he is doing with meth. Only run the proper mixture. Straight meth will eat blower blades. If you're running a tune based on the meth injection and the meth bottle runs empty, DO NOT go full throttle. Meth is there as a safety net to let you produce the same results as running higher octane fuel without having to actually run higher octane fuel. Meth runs out at full throttle, you risk going boom.
An aluminum tank won't keep your methanol any cooler than a steel tank, but I would choose aluminum just for the weight saving. Alum is 1/3 the weight of steel. Also both methanol & ethanol corrode steel faster than aluminum, so another vote for aluminum.
The reason methanol & ethanol feel cool to the touch is because they evaporate fairly fast & it feels cool on your hands because the heat is being taken away with the evaopration. This is the same with all alcohols. Same as when you inject it into your engine. As soon as the alc. gets sprayed out of the injector & hits the air stream, it immediately begins to evaporate & cool the air & your engine.
As for where to buy it, I'd check with American Muscle first. Everybody on MF seems to be happy with their products & service.
My friend, you can never have enough horsepower. Speed is a sickness.
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
