how do i activate fuel pump
Old Jan 28, 2013 | 01:16 PM
superdutyfan's Avatar
superdutyfan
Default how do i activate fuel pump
how do i turn on the fuel pump to pump out the fuel in the tank. i was going to unhook the fuel line before the fuel filter and use the cars fuel pump to pump the fuel out. or if anone has a better idea on draining the fuel tank please feel free to respond.
thanks sdf
Old Jan 28, 2013 | 01:24 PM
waykooljr's Avatar
waykooljr
I'm pretty sure the fuel pump comes on when the key is turned to the on position, without starting.
Old Jan 28, 2013 | 01:41 PM
Ditty's Avatar
Ditty
Turn key to "ON" position. Fuel pump is provided with power and starts to pump fuel.
Old Jan 28, 2013 | 02:07 PM
superdutyfan
^^^ thanks guys for the quick replies
Old Jan 28, 2013 | 04:43 PM
moosestang's Avatar
moosestang
It will run for 3 seconds when the turn the key to on. I'm not sure how long that will take to drain the tank.
Old Jan 28, 2013 | 07:46 PM
superdutyfan
that will take a while is there any way of keeping the pump on ?
Old Jan 28, 2013 | 08:26 PM
Dawghouse's Avatar
Dawghouse
I found this on another forum might work. "Go to your local auto parts store & get a $15 auxiliary fuel pump & 10-15ft of 3/8 rubber fuel line & some hose clamps. Put about 10ft wire leads /w alligator clips on them & hook it to a battery/power source & let it pump away."- shortstuf121 from http://www.allfordmustangs.com/forum...-out-tank.html
If your going to be removing fuel often you might look into http://www.northerntool.com/shop/too...9224_200129224 or something similar to make your siphoning go faster.
Old Jan 28, 2013 | 11:34 PM
petrock's Avatar
petrock
YOu could just use a syphon pump. Walmart has one for 18. I’m not sure how good it is though, but it will definitely be faster then turning the key on/off over and over again to get the gas out of your tank.
Old Jan 29, 2013 | 10:20 AM
superdutyfan
can't syphon out of any 2005 or newer ford. have to take the fuel line off at the filter and the activate the fuel pump or remove the fuel tank. but there must be a way to bypass the relay or what ever to make the pump think the car is running.
Old Jan 29, 2013 | 10:34 AM
moosestang's Avatar
moosestang
I'm sure you can use a jumper wire in place of the relay, but i've never had to do it.
