how do i activate fuel pump
Old Jan 29, 2013 | 11:21 AM
waykooljr's Avatar
waykooljr
Found this in a service manual...
Fuel Tank Draining
Old Jan 30, 2013 | 01:27 AM
petrock's Avatar
petrock
Originally Posted by superdutyfan
can't syphon out of any 2005 or newer ford.
That doesn’t make sense. Stick a tube down the gas filler neck until it is in the tank and syphon the gas out. What is in the 2005 and newer fords that prevents this from working?
Originally Posted by moosestang
I'm sure you can use a jumper wire in place of the relay, but i've never had to do it.
Yes, you could do this (with the key on, engine off) but if you jump the wrong pins you could easily fry your PCM by sending a high amount of current down a low current circuit, or blow a fuse if your lucky.
Fuel Tank Draining
Yeah, the manual is telling you to use an expensive tool to syphon out the gas through the gas filler whole/tube. It sticks a long tube down into the gas tank and sucks the gas out. Same as a hand syphon pump.
Old Jan 30, 2013 | 10:28 AM
superdutyfan's Avatar
superdutyfan
I tried a hand pump and about 8 ft of hose and it will not reach the fuel there is something blocking it. I talked to the dealer and they said they are syphon proof to prevent theft of fuel since the new cars and trucks do not have gas caps. they can do it by unhooking the fuel line at the fuel rail and the have a program they hook up to the car and it will tell the computer to turn on the fuel pump. a ford program 5500 bucks they wont or cant sell it even if a person wanted to buy it.
Old Jan 30, 2013 | 01:52 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Originally Posted by Dawghouse
I found this on another forum might work. "Go to your local auto parts store & get a $15 auxiliary fuel pump & 10-15ft of 3/8 rubber fuel line & some hose clamps. Put about 10ft wire leads /w alligator clips on them & hook it to a battery/power source & let it pump away."- shortstuf121 from http://www.allfordmustangs.com/forum...-out-tank.html
If your going to be removing fuel often you might look into http://www.northerntool.com/shop/too...9224_200129224 or something similar to make your siphoning go faster.
I would not use alligator leads. You are dealing with Fuel and fuel vapors here in a confined space. The last thing you want is an ignition point (spark) if the lead pops loose, KABOOM!
Anyways, use the appropriate connectors to attached the pump to the wires, and make the connection point where you turn the juice on through a switch or at least 4 or 5 feet outside of the vehicle to reduce unintended combustion.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
