drive shaft
Old Feb 1, 2013 | 06:14 PM
1bad07's Avatar
1bad07
i will keep you guys posted as how it comes out ive done this before using a metal/steel whatever you want to call it on a truck and worked pretty damn good but never on a s197. thanks for your feedback xx10GT not to be sarcastic or anything but ive done a little fabrication on headers and that did come out awesome. like i said guy no offense to anyone just want to get the most feedback on what is out there .
Old Feb 1, 2013 | 06:28 PM
moosestang's Avatar
moosestang
Originally Posted by 1bad07
i have a ford ranger one and a buddy that does balancing on driveshafts has a shop ... just wondering if anyone has done one
the spyder drive shaft for the s197's are made from ranger shafts. I would have to be really competent in welding aluminum and even then I might not try to make my own. It's just not worth the risk.
These cars come with a heavy steel two piece driveshaft for a reason. It dampens all the drive line vibration. You didn't think they engineered this marvel to save money, did you?
Old Feb 1, 2013 | 07:13 PM
1bad07's Avatar
1bad07
so what would you say the 1peice they sell for 799 are made of or what woukld be different or finding a spyder shaft and using it rather than making my own just curious
Old Feb 1, 2013 | 07:14 PM
1bad07's Avatar
1bad07
or those that take a 3v engine and put in a rat rod or ford ranger and make their own ds
Old Feb 1, 2013 | 07:58 PM
moosestang's Avatar
moosestang
Do you weld aluminum every day? That's my point, the guy that makes the spyder drive shaft does it for a living. The DSS has a machine that spins the thing up to 9500 rpms, does your buddy have that?
If you are a good welder, then have at it, but just know that you may experience more vibration with a 1 piece drive shaft. I have a 1 piece steel drive shaft from Denny's drive shaft, who have been in business making custom drive shafts since the 70's. They quit making them for the s197 because of all the vibration issues.
If I were buying or making a drive shaft today, I'd be using a cv joint at the rear like the stock drive shaft. That wasn't an option when I bought mine in 2006.
Does anyone know the story behind the twisted stock drive shaft in this thread?
http://www.allfordmustangs.com/forum...factory-2.html
Old Feb 1, 2013 | 08:11 PM
1bad07's Avatar
1bad07
i wont be welding it the driveshaft shop will they have a machine that spins and welds along with balancing ....... just dont want to spend 500-700 on a aftermarket one when i already have had the ranger one and the ranger one i have looks exactly like the one they sell thru american muscle but idk what the difference is other then the length
Old Feb 1, 2013 | 08:25 PM
moosestang's Avatar
moosestang
Well you made it sound like you were going to weld it in your back yard. There is likely no difference in the materials used. I'm pretty sure they all use the same aluminum tubing. In order to connect it to the pinion, you'll need to make an adapter or change your pinion flange.
I still would prefer having the CV joint at the pinion, but you might get lucking and have a car with no vibrations. A lot of people will blame the 1 piece drive shaft for vibrations, but the reality is that the vibration was always there. The stock drive shaft just cancels it out very well.
Old Feb 1, 2013 | 08:32 PM
1bad07's Avatar
1bad07
No no im not welding it and yes i was planning on changing my pinion flange to a cobra one
so what is under the scrungee looking black boot ......
Old Feb 2, 2013 | 12:02 AM
808muscle's Avatar
808muscle
I heard there was a 9 lb weight stuffed in that stock DS. Good times ford..... Cover up those factory vibrations.
Old Feb 2, 2013 | 11:25 AM
moosestang's Avatar
moosestang
Some type of slip joint. If I can get mine off without destroying it, I'll take a pic.
