Door Panel Question
Old Feb 16, 2013 | 07:56 AM
LordRipberger's Avatar
LordRipberger
Default Door Panel Question
Hey guys,
Well it is now 2013 and my car is from 2006. I guess the plastic things are starting to get loose in the cabin.
I have a ratte in my door. I figured it out that it is the small panel inside the door area. So if you were to grab the handle from inside the car, then extend your fingers you would hit the panel I am referring too. I can literately shift the panel back and forth. Does anyone know of a way to stop this rattle?
Thanks.
Old Feb 16, 2013 | 08:17 AM
Rudolph Hucker's Avatar
Rudolph Hucker
i have the same dude..my cars gone 12k miles 2007 vert..right where the door opener is right?
Old Feb 16, 2013 | 08:34 AM
LordRipberger
Its below the door opener. Its behind the handle. Where you would grab to close the door once your in.
Old Feb 16, 2013 | 08:45 AM
Rudolph Hucker
yeah when i hit a big bump it rattles like crazy..stops if i push my hand on it though..
Old Feb 16, 2013 | 11:43 AM
BrandonsBlueStang's Avatar
BrandonsBlueStang
I took that small panel you are referring to off, put a decent amount of foam between the panel and the door panel and put the panel back on. Don't put too much to where you can't get the panel to go on right but get enough so it will stop moving so freely. Worked for me.
Old Feb 16, 2013 | 12:00 PM
Rudolph Hucker
hi.
is it easy to remove the door panel dude?
Old Feb 16, 2013 | 09:29 PM
BrandonsBlueStang
To do what I suggested simply requires you to remove "item 8" in this diagram. (I thought that's the piece you two were referring to) Anyway, here's a link to some instructions on how to remove the door panel completely.
http://iihs.net/fsm/?dir=441&viewfil...Trim+Panel.pdf
Shawmp
Sep 18, 2015 07:52 AM
2k232
Sep 16, 2015 10:28 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
