700hp coyote
Old Feb 17, 2013 | 11:10 PM
awbreyjd's Avatar
awbreyjd
we are kinda testbedding now. seeing what the stock block from the 2013 can do. 721 was at 7696. Redline is set for 7800 but the car seems to wanna make more power. I am kinda scared to push it to 8000 because I do want it to last a little bit. Gonna keep redline where it is usually shift about 7500. Fingers crossed as I plan on going to the local track friday for its opening of the season. its an 1/8th mile but should be able to work on my launch. Then be ready for when a fairly local 1/4 track opens.
Old Feb 18, 2013 | 11:52 AM
awbreyjd's Avatar
awbreyjd
the graph wasnt rescaled so it only shows 719 but its the same run.
Old Feb 18, 2013 | 02:54 PM
Andy13186's Avatar
Andy13186
beastly
sounds like it just keep revving... and i guess it does
Old Feb 18, 2013 | 03:12 PM
awbreyjd's Avatar
awbreyjd
Yea the car just revs and revs. With the boss heads/cams along with the modified pulse ring it can go to 8100 if we wanted.
Old Feb 19, 2013 | 08:14 AM
awbreyjd's Avatar
awbreyjd
according to the interceptor gauge 1/4 mile test the car went 10.7 at 132. Not sure how accurate those are.
Old Feb 19, 2013 | 11:22 AM
jpplaw's Avatar
jpplaw
Are you hitting 700hp+ using 47lb injectors? What is the fuel pressure turned up to?
Old Feb 19, 2013 | 11:54 AM
awbreyjd's Avatar
awbreyjd
yes 47# injectors. it hits 60 at full boost.
Old Feb 19, 2013 | 12:17 PM
beerman616's Avatar
beerman616
Sounds like a beast!
Old Feb 20, 2013 | 11:39 AM
awbreyjd's Avatar
awbreyjd
thanks, it breaks the tires loose at 80 in this cold weather. So much fun to drive.
Old Feb 20, 2013 | 08:09 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
What suspension & tires are you running?
