Clutch help ASAP!
Old Feb 20, 2013 | 10:15 AM
MadMike1337's Avatar
MadMike1337
Default Clutch help ASAP!
All. I had an excedy 500 clutch/flywheel installed yesterday with new slave and what not. I was able to start the car but can not get it in gear. F! Ideas?!
Old Feb 20, 2013 | 11:33 AM
whosniffedme's Avatar
whosniffedme
You HAD it installed or you did it yourself? Because if you had it installed then the fact that you can't drive out of the mechanics shop should be enough to have them fix it hahaha
Old Feb 20, 2013 | 11:40 AM
clowe1965's Avatar
clowe1965
Yeah that pretty much says it is not disengaging at all, assuming your shifter was reinstalled correctly. Did you bleed it properly? Check the part number that it is specified for you car and transmission.
Old Feb 20, 2013 | 12:05 PM
bigstick's Avatar
bigstick
Push the clutch in and out about 10-15 times.
If you did everything right, that will fix the problem.
Old Feb 20, 2013 | 03:06 PM
MadMike1337
After it was installed it worked fine after test driving it around. I'm guessing air was still in the lines. Not sure what happened over night. Pumped it about 60x and nothing. Then had my friend pump it about 80x yeah we counted lol after i took the res. cap off.
Old Feb 20, 2013 | 08:18 PM
turbo 2.8's Avatar
turbo 2.8
was the front drivers side jacked up while you were pumping? I just installed clutch, flywheel, and slave without a hitch this weekend.
Old Feb 21, 2013 | 01:52 AM
Diabolical!'s Avatar
Diabolical!
I would contact the installer.
Old Feb 21, 2013 | 07:26 AM
k_aimone's Avatar
k_aimone
This is correct
Old Feb 21, 2013 | 11:12 AM
MadMike1337
Correct. I jacked up the DSF when pumping. Next week i will take it back out for a drive. Hopefully I won't have an issue again.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
