P0506 Code help plz
Old Mar 10, 2013 | 12:14 PM
Steven Bannoura's Avatar
Steven Bannoura
Default P0506 Code help plz
Hey;
Going to start from the beginning, i got that same code about a year and a half ago after turning on my AC, wiped it out at autozone and it didn't come back. Last week, i took the car out after almost 2 months of not driving and after about 4 hours of driving or so, the engine light came on. I checked it and it was that same code, so i figured it might be a glitch or something cause i let my stupid friend take it for a quick ride around the block, i wiped it out and left the car in the garage for a whole week.
I took the car out last night and after about 4 hours or so, the code came back, so i know there must be a problem.
Code is P0506 and it reads : Idle Air Control System RPM lower than expected
I Google the problem and the closest thing i found was this;
http://www.justanswer.com/ford/3uesg...h-engages.html
That doesn't exactly give me a solution, so iam hoping one of you good folks would help me if experienced that problem first hand or know anything about it. I would like to mention that when i had it Dyno tuned last time, the tech mentioned that one of my O2 sensors is going bad and not working at a 100%, said something about the O2 sensor heater messing up.
2005 mustang GT Vehicle mods are :
JLT CAI
Steeda underdrive pullies
BBK short Headers
Off road xpipe
SCT 93 Octane Tune
Any help would be Appreciated
Old Mar 10, 2013 | 01:15 PM
SpartaPerformance's Avatar
SpartaPerformance
What do you mean? All the possible causes and diagnostic aids are right there
Old Mar 10, 2013 | 02:09 PM
Steven Bannoura
I guess i would rather hear it from some people who had this issue before, before start messing with anything else. I just took out my CAI and looked into the throttle body and it seems ok. It has a bit of dirt around the butterfly but i don't think that causes the issue, how clean does it have to be to run properly ? There isn't dirt covering it or anything, just a bit around it which looks like normal use.
Old Mar 10, 2013 | 02:26 PM
Joenpb's Avatar
Joenpb
The fault code is a "functional fault" as opposed to a particular "part" fault. That means you'll have to diagnose it. It looks like you got a great answer to your question on the other site. Now its time for you to get busy, or take it to a dealer. Good luck.
Old Mar 11, 2013 | 02:16 AM
akdoggie's Avatar
akdoggie
Check this out. It should help you
http://www.obd-codes.com/p0506
When I did mine on my F150 with 4.6, it turned out to be a dirty throttle body. Looked clean but the holes were slightly clogged.
Old Mar 11, 2013 | 09:04 AM
awbreyjd's Avatar
awbreyjd
^this
Old Mar 11, 2013 | 10:38 AM
Steven Bannoura
thx for the tips, gonna get busy then i'll update if anything changed.
Old Mar 22, 2013 | 10:00 AM
Steven Bannoura
wow this car is weird . I had a tech look at it at my shop, he told me not to worry about it since it takes so long to come back, he just wiped the code and i have been driving the car since, the code hasn't come back yet. It has been 2 weeks or so.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
