whining noise after JLT/BAMA install
Same opinion as above here. Were you used to not hear your air being drawn in, now you can. You are moving a considerable amount more to now. Not 1000 CFM, but you did gain the ability to breath. Making a little more HP now!
just finished test driving 2012 GT with the JLT/Bama combo. went out on the race tune and every time i go WOT, i get a 1 to 2 second whine....kinda sounds an airgun noise.
any ideas?Attachment 33708
Attachment 33709
Attachment 33709
I hope this helps, let me know if you have any questions or need some assistance! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
Attachment 33709
Attachment 33709
Thanks AMDanBailer.
I appreciate the support. In fact, I did come across some trouble with the install; can you tell from the pics?
The new screw connecting the MAF sensor broke inside the grommet an left the shaft of the screw in the hole. I tried needle-nose pliers to get it out, but no go. And i couldn't try to punch it through b/c there plastic backing inside the air tube. After some thought, I used some double sided M3 tape (white stuff behind the MAF) and a zip-tie to hold it in place. I hate leaving it like that for the long haul, but it was the only thing I could do at the time.
I have this same sucking in sound with my Steeda intake when I get on it. I also have a wizzing noise that I'm not sure is normal. I'm going to try to remove that sound tube and see if that does anything.
