Sponsored by:
Sponsored by:
Any of you with aftermarket control arms, input please
Old 04-12-2013, 11:54 AM
ghunt
ghunt's Avatar
Default Any of you with aftermarket control arms, input please
Alright, I have Spohn lower control arms with standard poly bushings in them. They squeak all the damn time, going over the slightest bump or anything that causes any kind of suspension movement. I thought with good silicone grease that wouldn't be an issue but apparently I was wrong.
Is this just a fact of life with polyurethane control arm bushings?
Also, on the subject of greasing, what is the typical greasing schedule for control arms? I bought a tube of silicone grease just for those control arms (and possible future upper arm) but no idea on the interval for greasing.
ghunt is offline
Old 04-12-2013, 01:41 PM
Menace
Menace's Avatar
Make sure they are properly torqued, I believe it was 130 ft/lbs if memory serves me...
Mine squeaked (Steeda Chromoly) when I first installed them but no longer squeak and I haven't applied any grease since installed. I'd say about 4-5 years ago.
Menace is offline
Old 04-12-2013, 04:16 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
My UPR arms don't squeak. I've put around 30k miles on them.
UPRSharad is offline
Old 04-12-2013, 05:52 PM
jbodak31
jbodak31's Avatar
I have CHE lower control arms, no speaks ever.
jbodak31 is offline
Old 04-12-2013, 08:19 PM
vixr
vixr's Avatar
X2 on the torque... I have BMR lowers with poly bushings and steel sleeves inside. I could see some cuts in the poly around the sleeve to let grease between. I used mercury 101 special lube, the green stuff. Not a single squeak. Steeda adj upper, same thing.
vixr is offline
Old 04-12-2013, 08:27 PM
moosestang
moosestang's Avatar
This is the grease you should be using.
Energy Suspension 9.11104 Formula 5 Prelube Grease - 8 oz. : Amazon.com : Automotive Energy Suspension 9.11104 Formula 5 Prelube Grease - 8 oz. : Amazon.com : Automotive
That tub will last you forever. It's sticky as snot, so wear gloves or wash your hands with gasoline afterwards.
moosestang is offline
Old 04-13-2013, 01:11 PM
aaaa1236
aaaa1236's Avatar
Mine started squeking about a month ago, i greased them and they are quiet again.
aaaa1236 is offline
Old 04-13-2013, 05:33 PM
SpartaPerformance
SpartaPerformance's Avatar
I use CHE also!!
SpartaPerformance is offline
Old 04-13-2013, 07:28 PM
808muscle
808muscle's Avatar
J&M LCA and only greased them with the packet provided. No squeaks in two years.
808muscle is offline
Old 04-13-2013, 11:15 PM
VistaBlueFrank68
VistaBlueFrank68's Avatar
Get the FR Boss 302 LS LCA for $500 with the FR relocation brackets then let me know how poor you feel.
VistaBlueFrank68 is offline
Quick Reply: Any of you with aftermarket control arms, input please
