Roush Phase 2 kit
Old Jun 20, 2013 | 01:43 PM
  #21
Andy13186's Avatar
Andy13186
What is the location and name of the shop that is quoting you this price? I live in florida too and im kind of interested.
Old Jun 20, 2013 | 05:01 PM
  #22
winkawak's Avatar
winkawak
Custom Cars/ Speed Fanatics
561-752-3693
theres more shops in florida, look it up in roush site
Originally Posted by stephen1371
no tune is needed for any exhaust change on the new 5.0's. They are conservative because they run really rich (way better than running lean) for warrenty reasons, if you get an aftermarket dyno tune it will be voided. With an auto and a stall you can touch 10's. I am about to part mine out and trade mine in, it's a 5 speed when I get the new coyote I will be getting an auto for drag racing.
is the conservative roush tune still fun or exciting to drive? Does tune like vmp lean out the engine more? more hp?
Old Jun 20, 2013 | 06:22 PM
  #23
stephen1371's Avatar
stephen1371
A custom dyno tune would give you more hp, but the canned Roush tune is still going to be a huge improvement over stock. The shop you are having the install done at can probably do a custom tune for you. But yes to answer the leaning out question they will lean it a lil and increase timing, in my opinion, I would have a custom tune either directly or get with a tuner of your choice to do a remote tune.
Old Jun 20, 2013 | 09:48 PM
  #24
winkawak's Avatar
winkawak
I would probably stick with the roush tune for awhile see how it goes and decide from there. Gonna call the roush specialist again see if they can throw in a dyno run before and after the install.
Old Jun 21, 2013 | 02:06 PM
  #25
stephen1371
Not a bad idea, they might charge you around a 100 extra each time though, stock through an auto id say mmmm 370-380ish from other stock I have seen, but times are better than number in my opinion
Old Jun 22, 2013 | 11:49 PM
  #26
winkawak's Avatar
winkawak
will supercharged motor have heat issues if i take it for a long trip or driving it all day none stop? Also do you recommend upgrading brakes?
Old Jun 23, 2013 | 05:15 PM
  #27
stephen1371
Heat soak isn't a huge problem for the tvs, not saying it cant happen just not very common on normal driving. Now if you take it to the track and beat on it all the way there and then hot lap the car yes you while probably see some heat soak. Brakes and tires go hand in hand something a lot of people tend to forget, wider front tires also help you brake faster. When you apply your brakes its your tires that have to transfer this movement. If you have the brembo package no, if not I see no reason for a dd to have to upgrade them. Do some stainless brake lines if you want its a huge improvement over the stock expanding rubber ones, maybe some super blue break fluid and some good pads and you will probably stop twice as good as stock. this is MY OPINION ON THIS.
Old Jun 23, 2013 | 11:16 PM
  #28
winkawak's Avatar
winkawak
thanks, what are some things i can upgrade to keep my sc motor cooler? im planning to beat on it every chance i get on a long trip to cali.
Old Jun 24, 2013 | 04:37 AM
  #29
stephen1371
afco hear exchanger would help, make sure when doing your gauges install a IAT guage then, wide band is also a must. Why not go with a Paxton they don't heat up as fast and are just as good as the tvs if not better. Guy you can find on here or on www.S197forum.com, screen name should be Beefcake, he can get you the best deal on a vortech or a Paxton. He runs something like 8.5 with his, he was trapping at over 166 at a recent event.
Old Jun 24, 2013 | 12:02 PM
  #30
winkawak's Avatar
winkawak
I got so caught up asking so many questions forgot to thank you for helping out. Thanks.
