Constant "chirping" squeak from rear suspension- LCA'S?
I would if I were you. If the bushings are in a bind/twist they will wear out a lot quicker. Good luck...
This prevents binding of the bushing. Binding puts additional stress on the bushing and can cause it to twist and break up. At the very least you end up with squeaking. That's your bushings calling out for help!
thanks guys that is probably the issue, never loosened up the LCA's and let them re-set themselves after the installing the lowering springs, have to check to see if the bushings are even still good, but I might just order new aftermarket LCA's. Also, it seems viewpoints are conflicting about whether or not an adjustable panhard bar is necessary in this situation with just rear lowering springs. Currently I DO NOT have one installed.....
Talked to a mechanic today about it. He obviously said that to really know I'd have to bring it in but as far as suspension lube goes, he said the bushings aren't going to take any grease so he doesn't think that will do much.
I do think it's the LCAs though. Was racing around with a friend on the highway the other day and hit some real high speeds. The car was whining like a mother ****er after that in the rear. Maybe the shocks too? Horrible chirping sounds. Sounds like animals in the back of the car. It has 82k miles with original everything in the suspension except lowering springs. Again, it did this even before the lowering springs were in but seems *slightly* more often now that they are in. Barely though.
Haha we definitely have the same problem chirps like crazy on the highway like animals are back there. I've been pretty busy lately but am going to do change the LCA's when I get a chance. Keep me posted if you get to it before me and it solves your issue. I might just do the shocks at the same time too since I still have the original ones installed.
The struts are a different story, half/one day's work with the assemblies.
*UPDATE*- Installed new J&M rear lower control arms today in place of my worn out originals and my horrible annoying squeak/chirp is finally gone!! when I took the old ones out the bushings were shot and dried out. If you have the squeak as shown in the youtube video in the beginning of this thread, it is your lower control arms. replace 'em!! recommend these J&M's so far.
Glad to hear you got it fixed. Worn out bushings will cause weird problems. I will say that a slightly cheaper, but more labor intensive, option is to replace the stock, worn out, bushings with polyurethane bushings. I like Energy Suspension’s bushings. Its a lot cheaper then new control arms. But the labor is higher because you have to remove the old bushings, which can be a PITA sometimes. But with a little heat, a C-Clamp style ball joint press and a bunch of patience you can do it in your driveway in a day or so.
