New engine cost?
Old Dec 19, 2013 | 09:36 AM
  #21
Murphdog's Avatar
Murphdog
Coyote!!!!!!!
Old Dec 19, 2013 | 02:45 PM
  #22
Fox Fader's Avatar
Fox Fader
1/2 the engine is not producing power?
If it did jump time, get that engine rebuilt.
Old Dec 19, 2013 | 03:42 PM
  #23
RazorGT's Avatar
RazorGT
OP I'm crying for you I also have a 06 GT and if this happened to me IDk what i'd do, I also try to take the best care of my car, but sometimes things happen Can you afford the repair the bill? hope everything will be okay keep us updated.
Wouldn't it be awesome if you got a BAMA tune and this whole problem went away?
Originally Posted by Murphdog
Coyote!!!!!!!
OP AM sells 5.0 engines but idk how much it would cost to install it.
http://www.americanmuscle.com/coyote-crate-engine.html btw whats the difference between their "crate engines" and "sealed engines"?
edit: nvm looked up some info on coyote swaps, and its cheaper to trade in for a 5.0 mustang!
what would you guys do in OP's situation? would it be best to chalk out 6k+ or get another mustang?
Old Dec 19, 2013 | 04:35 PM
  #24
waykooljr's Avatar
waykooljr
I'd be looking into rebuilding, maybe even building up the bottom end for later upgrades!
I don't get why they'd try to sell you an entire engine if the block is still good, other than to rake you over the coals.
You can get a complete long block for ~ $3k here, just sayin
Did the dealer quote you what they'd charge to rebuild your engine? Even so, I'd look for a reputable shop to do the rebuild.
Old Dec 19, 2013 | 04:50 PM
  #25
RazorGT's Avatar
RazorGT
nice advice! i would imagine rebuild to be cheaper and smarter option.
Hey stupid question, but what is the difference between long block and short block? is it the ford equivalent of GM's Big block and small block?
so is the stock 4.6L mustang Gt engine a long or short block v8?
Old Dec 19, 2013 | 05:56 PM
  #26
waykooljr's Avatar
waykooljr
Here's some definitions for you...
http://en.wikipedia.org/wiki/Short_block
http://en.wikipedia.org/wiki/Long_block
Take this short block for example, ModMax 4.6
Keep in mind, this short block is built to handle up to 1000 HP.
Compare that to the long block I linked and you'll see the difference.
Old Dec 19, 2013 | 05:59 PM
  #27
Art161's Avatar
Art161
Long block--engine assembly consisting of the block, crankshaft, camshaft, bearings, pistons, rings, connecting rods, oil pump, oil pan, timing covers, seals, cylinder heads, and intake manifolding, all installed.
Short block--engine block with all internal parts, such as the crankshaft, rods, pistons, and appropriate bearings, but without parts external to the block, such as the heads and valves, and the intake and exhaust manifolds.
Old Dec 19, 2013 | 06:52 PM
  #28
Chromeshadow's Avatar
Chromeshadow
It doesn't sound like the block is bad, sounds like a timing chain on one side slipped.
If you haven't worked on an overhead cam engine, I wouldn't suggest starting with this project.
I vote for: 1. find a reliable mechanic, sounds like the dealer sees a pot of gold. I think the timing chains should run about $1,500 to replace. Make sure both sides are done, make sure you get all of the old parts back!
2. Get a used engine and get a buddy to help you switch. Used engines from Salvage yards have a warranty to make sure you get a good one, you can switch it in a weekend pretty easily. I'd stay with the same year and from the same Mustang to keep things simple.
Old Dec 19, 2013 | 07:10 PM
  #29
outceltj's Avatar
outceltj
If the car is paid off is rebuild the motor with a 302 or 326 that was already mentioned. Get it ready for some major power. But some don't care to mod that much. It will be interesting to see what he does
Old Dec 19, 2013 | 07:12 PM
  #30
outceltj's Avatar
outceltj
Not to mention if the mechanic claims he's sees sludge and you always change the fluid sounds fishy. Have u seen it in person
