Need help! Rh headlight doesnt work
Old Dec 22, 2013 | 10:06 PM
1SilverGT's Avatar
1SilverGT
Exclamation Need help! Rh headlight doesnt work
I bought new bulbs and it still didnt work! I used the same bulb on both connections to see if it was the connection and it is. Anyone know how to fix it? Is it the wiring or just the connection
Old Dec 23, 2013 | 02:31 PM
Nuke's Avatar
Nuke
Have you verified no voltage at the socket with a VOM? Here's a link to the wiring diagrams for the 05's thru '10 (more or less). I don't know how much they changed the electrical systems after 10': http://iihs.net/fsm/?dir=40
Old Dec 24, 2013 | 12:45 AM
drummer829's Avatar
drummer829
Use a little voltmeter, if it's working then I'd go to the fuses next.
Old Dec 25, 2013 | 06:40 PM
1SilverGT's Avatar
1SilverGT
Ill check it, do you know which # of the fuse is it
Thanks guys
Pyrate Dave
Sep 10, 2015 07:30 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
