leak down tes
Old Sep 18, 2015 | 09:17 AM
bconboy's Avatar
bconboy
Default leak down tes
I have 2005 gt 4.6, how can I do a leak down test with motor out of car and heads off. the number 5 cylinder had a crack and I had a new sleeve put in. same problem after new sleeve was put in and I need to figure out if the sleeve did not work or if there is another problem. the cylinder was defiantly cracked.
Old Sep 18, 2015 | 12:51 PM
JimC's Avatar
Super Moderator
With the heads off the engine how will you do leak down? You have to seal the cylinder to test it for leak down so I don't see how you can do it, unless you fabricate some type of plate to fix to the engine to seal it.
Old Sep 18, 2015 | 02:35 PM
jwog666's Avatar
jwog666
lol, no leak down test. a this point i would call it quits on that block and get one that isnt cracked or sleeved
Old Sep 18, 2015 | 02:48 PM
bl817's Avatar
bl817
was the sleeve bored out to factory specs? did you replace the piston rings for that cylinder? piston? what state of build up is the motor in now? like jwog said, its gonna be tough to get a leak down test without the heads on. need more info
Old Sep 18, 2015 | 05:16 PM
Granatelli Sales's Avatar
Granatelli Sales
Former Sponsor
The heads have to be on the engine to leak down test it. Tear it down, send the block out to be magnafluxed and pressure tested. Chances are that block is wasted if you have had issues with it before.
Old Sep 23, 2015 | 02:52 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Bad idea to throw more money at block that is already known to be messed up. Go to a Junk yard and find a motor to start fresh with.
If you insist on working with what you got. Send the heads and block out to an engine rebuild shop. They can test it correctly and magnaflux it as Granatelli stated and redeck it if needed.
Old Sep 24, 2015 | 01:55 PM
Roy_R's Avatar
Roy_R
This screams crate motor!
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
