"sidewalls" on seats
I've seen this from the first time I have gotten into my car that it is easy to drag your butt across the sidewall of the seat. Before I got my 05 i saw a few wrinkles from the previous owner dragging his butt across the seat. When i sat in a 03 roush it was not nearly as difficult to get out without doing this. Any one else have a llittle wear and tear on their sides from getting in and out? It isn't that big of a deal just as long as Ford replaces them if they crack in a year or so.
RE: "sidewalls" on seats
I noticed a little wear on the side of the seat by the way I was getting in being lower makes it worse. I started changing the way I get in the car. The one thing that you need to look for is the front of the seat. The leather will come loose and become like a flap both driver and passenger seat did it on mine. There is a Tsb on that one Ford has already fixed both of my seats.
Technical Service Bulletin. It details any know problems for a specific issue and Fords recommended fix. They are distributed by Ford to the dealers, but are very easily found on-line.
If you are experiencing any problems with you car, you may want to look into them, especially of the problem is intermittent. If there is a TSB on the issue it normally lends your case with the mechanic some more credibility.. not to mention a recommended place for him/her to start looking at for the repair.
I think it's unlikely that Ford's going to replace the pleather after it cracks in a year. Wear and tear item. In the first week or month, probably - a year later, doubtful.
I'm going to save my pennies and replace my front seats with some Recaro's or recover them all in leather once the cracks turn into crevices.
GT350 S550 Tech
09-29-2015 03:29 PM
