intremittent engine overheating
Old Nov 10, 2016 | 06:44 PM
Su Roberts's Avatar
Su Roberts
Default intremittent engine overheating
my 2005 mustang gt is starting to suddenly display engine overheating. It has done this off and on but not constantly. Any suggestions.
Old Nov 10, 2016 | 07:27 PM
Urambo Tauro's Avatar
Urambo Tauro
Is there any pattern to the conditions under which it tries to overheat? (Like only when stopped in traffic, etc.?)
Has any part of the cooling system been serviced recently? (Fluid change, etc.?)
How "suddenly" does the dash report overheating? Is it just a swift motion from C to H, or does the needle erratically jump?
Old Nov 11, 2016 | 06:27 AM
Su Roberts's Avatar
Su Roberts
It's very sudden it goes instantly from c to h. I did a systems check and said everything is ok. It happened a few weeks ago then again yesterday
Old Nov 11, 2016 | 08:14 AM
Su Roberts's Avatar
Su Roberts
I also want to add I pulled over immediately when I felt the hood it was still cold
Old Nov 11, 2016 | 09:16 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Those are the typical symptoms of a thermostat that's stuck closed. Replace it ASAP before you end up with a blown head gasket.
Old Nov 11, 2016 | 01:43 PM
dusman59's Avatar
dusman59
Feeling the hood is not a good indicator. Doing the basics will help to pinpoint the problem. You can use a Infrared thermometer to get a reading at the thermostat housing. Make sure your fans are running properly and fluid level is correct.
Old Nov 11, 2016 | 05:43 PM
Urambo Tauro
I'm afraid I don't know much about how thorough the "systems check" is, but your description sounds like a fault in the gauge, the temp sending unit, or somewhere in between.
I like dusman59's suggestion. Run those basic checks and see if it really is overheating.
Old Nov 15, 2016 | 09:41 PM
flash_xx's Avatar
flash_xx
It's the fan controller module. Mine started doing that too. I Just replaced the whole fan assembly with the GT500 one and got a 3 row aluminum radiator while I was at it, but the stock GT fan is pretty cheap, no point in replacing just the module.
https://lmr.com/item/LRS-8607L/2005-...g-Fan-Assembly
Old Nov 16, 2016 | 04:40 AM
Dino Dino Bambino
A non-working fan would cause a gradual rise in the coolant temp. gauge from C to H, not a sudden one. I still think it's a sticking thermostat 'cause I had exactly the same thing happen a few years ago on my old '95 GT. Exactly 3 minutes after a cold start, the gauge would rocket from just above C to H almost instantly.
Old Nov 16, 2016 | 01:38 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That is just an OEM type replacement for the stock one though? Unless you linked to the wrong item?
Plastic Electric Cooling Fan
OE Design Mounts To Factory Locations
>>>>>Stock Airflow
