Sponsored by:
Sponsored by:
Low noise from front end when turning slow in parking lots
Old 06-28-2017, 03:35 PM
kevsgt
kevsgt's Avatar
Default Low noise from front end when turning slow in parking lots
Car is at 125,000 miles. When turning slowly in parking lots, i've started getting a noise that seems like its coming from the steering column. Sounds like a low pitched squeal or rubbing. I can sort of feel it at my feet as well. I thought maybe to do with the power steering? The power steering fluid is at proper fill level. Perhaps related to the rack and pinion? What should I look at? Thanks!
kevsgt is offline
Old 07-03-2017, 10:02 AM
kevsgt
kevsgt's Avatar
bump.
kevsgt is offline
Old 07-05-2017, 01:38 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Is it just happening when you are turning the steering wheel or when you are holding the wheel in the turned position like if you were going in a circle?
Derf00 is offline
Old 07-06-2017, 09:44 AM
kevsgt
kevsgt's Avatar
Only when turning the steering wheel. It comes and goes, hasn't done it in a few days now.
kevsgt is offline
Old 07-06-2017, 05:34 PM
ericwudi0830
ericwudi0830's Avatar
power steering issue?
ericwudi0830 is offline
Old 07-08-2017, 05:57 AM
kevsgt
kevsgt's Avatar
But how do I diagnose?
kevsgt is offline
Old 07-12-2017, 02:08 PM
kevsgt
kevsgt's Avatar
Bumping again. Car is still making the noise. Thanks for any thoughts.
kevsgt is offline
Old 07-12-2017, 05:58 PM
zinc02gt
zinc02gt's Avatar
Bleed the power steering and see if it continues. Could be a bad power steering pump. Another thing to check out is have a buddy in the car while it's on jacks. Have him turn the steering wheel and see if you can see any rubbing going on. I would do that before I bleed the power steering or go after a pump.
zinc02gt is offline
Old 07-13-2017, 10:07 AM
kevsgt
kevsgt's Avatar
With the car on or off? If I'm in Park, isn't there some sort of steering wheel lock? I suppose I could go to Drive, as long as the E-brake is engaged?
kevsgt is offline
Old 07-13-2017, 02:00 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Have you ever flushed your power steering fluid? Start there, if the problem persists, then look at a failing component.
Derf00 is offline
