Engine Operation Question
Old Feb 15, 2019 | 01:17 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Just a bit of a long
delay
Yeah, it shouldn't be kicking on/off if the AC or defrost setting is not turned on in the HVAC controls. Possible the controls aren't working correctly. To test this you would need to disconnect the HVAC control module connector behind the dash. Not difficult but you have to remove the top half of the center console to then remove the passenger side center stack cover (like if you were going to replace the car stereo). The connector is at the floor and has a rotating lock that disengage from the module after you 'unlock' it.
If you disconnect then drive around you can see if the cycling goes away, if it does, replace the module. If not, IDK.
stickbow9
Jun 18, 2014 07:05 AM
Jayhawks
Apr 14, 2014 07:10 AM
Rad Red 03
Jul 13, 2011 09:02 PM
rmodel65
4 Cylinder NA and Turbo
Jul 12, 2010 07:52 PM
Mr_Kebo
Jul 23, 2006 06:07 PM
