Sponsored by:
Sponsored by:
07 6v mustang p108
Old 07-22-2018, 10:55 AM
Juan Medina
Juan Medina's Avatar
Default 07 6v mustang p108
Hello new to forum...i have a 07 6v mustang started throw code p108 used a scan tool says it's my map sensor...need help locating the sensor can't seem to find it
Juan Medina is offline
Old 07-23-2018, 02:14 AM
08'MustangDude
Banned
08'MustangDude's Avatar
That code is too short for anyone to verify it, so we'll take your word on that.
The MAF is in the filter box housing tube, dunno how you are missing that.
Right where the hose clamps on to the air box, the sensor is right in front
of the clamp. It's a combination MAF and IAT sensor.
08'MustangDude is offline
Old 07-23-2018, 07:50 AM
GT Nate
GT Nate's Avatar
might check to see if that air intake tube doesn't have any rips or holes... You can also clean the MAF with MAF cleaner, but they do get less effective as time goes by...I put a new on my old 93 Tbird which was having horrible pinging... new one put on and the pinging went away forever.
GT Nate is offline
Old 07-23-2018, 03:36 PM
Juan Medina
Check the hose Every thing seems normal seen similar post about the p108 code on mustangs many said the map sensor is integrated with the egr valve.....
Old 07-23-2018, 05:05 PM
Juan Medina
Could this be true ...
Old 07-24-2018, 04:39 PM
08'MustangDude
Banned
Why can't you even type the code right? There is no P108, you're missing a digit!
You were already TOLD where the MAF sensor is.
Right there...
Old 07-25-2018, 02:24 PM
Juan Medina
The code is p0108 and I was right the MAP sensor is integrated with the egr valve took it to my mechanic bought a new egr valve code went away...
Old 07-25-2018, 02:26 PM
Juan Medina
Right there...
I didn't miss it because thats not what the MAP SENSOR!!
Old 07-26-2018, 12:19 AM
bl817
bl817's Avatar
unfortunately 08, you were wrong here. Mr. Medina has a V6 such as yourself and even tho he did leave out the first 0 in the code, the P0108 is indeed a MAP code for the V6. its integrated around the intake manifold with the EGR. I myself didn't realize that either, didn't know that Ford was still using EGR valves in 07 and probably till 09.the pic you posted is indeed the V8 MAF sensor and location.
bl817 is offline
Old 07-26-2018, 09:10 PM
08'MustangDude
Banned
Okay, so.... I have a V6, and here is my intake:
Same plug, same location as the one I posted. Top right, same place as circled in the previouse
post.
Quick Reply: 07 6v mustang p108
