Rear Differential Whine
Old Jan 30, 2019 | 01:53 PM
05RedFireMetallic's Avatar
05RedFireMetallic
Question Rear Differential Whine
Hello all,
I recently swapped to a 4.10 gear in my 2005 Mustang GT. Following the swap, I now have a mild whine coming from the rear end when cruising anywhere from 45 mph to 65 mph. When I accelerate in between those speeds, or am driving faster or slower than that, there is no whine. I'm wondering if anyone has tried the "Damper Kit" (Part No. 5R3Z-3C246-A) listed in TSB 09-20-4.
Thanks
Old Jan 30, 2019 | 02:37 PM
08'MustangDude's Avatar
08'MustangDude
Banned
That usually means the pinion-bearing preload was not done right, or loosened up.
Old Jan 30, 2019 | 03:18 PM
Urambo Tauro's Avatar
Urambo Tauro
How did the gear pattern look? Did you take any pics? Did you use a new crush washer to set pinion preload?
Old Jan 30, 2019 | 10:07 PM
lenko's Avatar
lenko
Usually Ford 410s set up nice and quiet if within spec. I've done 4 of those and all good. Only trouble I have is with the 373s which are a little more difficult, but that was the first install and they whined. Here's a good site to peruse for a gear setup. https://mustangforums.com/forum/4-6l...-overhaul.html
If you can find an article by James Adkins, he also has some great information. If there's not too much mileage on the gears it may be possible to correct the whine by ensuring they are adjusted to spec.
I did try the dampers with the 373 but ended up taking them off and they are in an upper shelf in the garage. They do add weight to the car, but I found them ineffective.
Old Feb 4, 2019 | 08:33 PM
pascal's Avatar
pascal
S197 Section Modder-ator
All good advices here but if Motive gears were used then that is your culprit. They're just not good. lol
Old Feb 5, 2019 | 12:42 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That is exactly what my first thought was but I couldn't remember the brand that people always said to stay away from (Motive).
Anyways, check the preload and recheck the contact pattern. Another possible culprit, although unlikely unless you lowered the vehicle, is the driveshaft pinion angle needs adjusting. .
Old Feb 5, 2019 | 07:32 PM
pascal's Avatar
pascal
Derf, I totally agree...if you're not 100% comfy to do the job yourself, let a pro handle this.
MineralGrey
19
Aug 17, 2009 10:09 AM
HamMach1
12
Jun 22, 2009 11:40 PM
1slwstang
Mar 18, 2009 09:17 PM
redneckstang
Feb 7, 2007 09:30 AM
Emann0007
Aug 2, 2005 09:08 PM
