Sponsored by:
Sponsored by:
Engine dressup TB screws
Old 02-18-2019, 03:19 PM
Ford_Dude
Ford_Dude's Avatar
Default Engine dressup TB screws
So I'm going to be installing a FRPP TB soon (Already have it in hand) and I'm interested in replacing the screws that hold it to make it look a little nicer.
I think I've seen it posted that the tops ar 8mm and bottoms are 10mm.
I know on mine the tops are screws and bottoms are studs and nuts.
I was thinking if I can find the right ones some Allen head screws would be nice, also might go with black screws as I think it'd have nice contrast with the TB.
I figure if that's accurate for the heads, it tells me nothing about the threads.
Ford_Dude is offline
Old 02-19-2019, 12:52 PM
Derf00
Gentleman's Relish
Derf00's Avatar
http://www.uprproducts.com/0510-must...ap-covers.html
http://www.uprproducts.com/mustang-b...s-set-8mm.html
http://www.uprproducts.com/mustang-b...-set-10mm.html
For bolts, it will be best to use covers that snap into place. That way you don't compromise the quality of the bolt holding the part in place.
I don't think you'll find anything for stud/nut combos.
Derf00 is offline
Old 02-19-2019, 01:57 PM
08'MustangDude
Banned
08'MustangDude's Avatar
For other engine dress up:
I did all I could get to on mine:
Also did the Fenders, cowl covers, every one, except one at the A/C canister, lower, need a
longer bolt... I did the four rear license plate bolts too.
08'MustangDude is offline
Old 02-20-2019, 03:02 PM
Ford_Dude
Ford_Dude's Avatar
I was thinking some thing like this.
Old 02-20-2019, 03:48 PM
08'MustangDude
Banned
Yes, we use those at the shop, and I polish them.
I use a cordless drill, and six different levels if sand paper, and I sand them smooth,
then start 600 grit wet to 1000, and I put a nice polish on them.
Old 02-21-2019, 12:16 PM
Ford_Dude
Ford_Dude's Avatar
Cool, I'm looking for some of that type, but black oxide coated instead of polished.
Would you happen to have the thread specs?
Old 02-21-2019, 01:07 PM
08'MustangDude
Banned
Polish them, THEN coat them... Or, black chrome...
Old 02-21-2019, 10:41 PM
Ford_Dude
Ford_Dude's Avatar
But do you have the thread spec? The top screws on mine are hex head and I'd rather change them to allen head like in that picture.
Old 02-22-2019, 08:25 AM
08'MustangDude
Banned
Take one out then run to a hardware store, Lowes, or Home Depot and
see what the thread pitch is.
Old 03-19-2019, 01:34 PM
Ford_Dude
Ford_Dude's Avatar
Well since no one had info on the specs I bought some screw and nut thread checking tools.
So for future reference in case someone sees this thread they're M6 1.0 (IE 6mm and 1.0 threads)
I bought some off belmetric.com along with some thick washers.
I plan to do this in phases.
1. just test fit to make sure I got the right length, I got 30mm though maybe I should have gotten 35mm.
2. once fitment is confirmed I plan to see able getting one set of washers (qty 4) powder coated black.
3. I'll then use the black powder coated washers when putting on the larger polished TB.
Gary Ugarek
21
04-14-2013 05:54 PM
blackstang14
01-11-2010 02:35 AM
4reboy
03-03-2008 09:59 PM
65coupe88hatch
08-31-2007 10:10 PM
StangMang
04-14-2004 04:59 PM
Quick Reply: Engine dressup TB screws
