Sponsored by:
Sponsored by:
2006 Mustang GT engine rattle
Old 06-25-2019, 11:55 PM
nonusername120
nonusername120's Avatar
Default 2006 Mustang GT engine rattle
Hello, I have 2006 Mustang GT that has a rattle when i rev up the engine. I talked to a Ford dealership and they said it was the timing chain, but when i opened it up the timing chain, the guide rails, everything was fine. I replaced it anyways while i was in there, but the rattle is still there. I'm hoping someone can identify the rattle or tell me of some diagnostic steps i can use to figure it out. Here is a link to an audio recording of my engine.
https://www.dropbox.com/s/0ejxn90z6m...10503.mp4?dl=0
Thank you for any help you can offer.
nonusername120 is offline
Old 06-26-2019, 01:27 PM
Derf00
Gentleman's Relish
Derf00's Avatar
What all did you replace while you were in there?
A common failure point for 05-06 4.6L 3v engines are the timing tensioners. They use a gasket and are made of plastics instead of a machine fit cast iron/aluminum so while the guides might be ok, the tensioner doesn't hold tension and allows the chain to bounce around even if the guides are ok.
Derf00 is offline
Old 06-26-2019, 04:51 PM
nonusername120
I replaced the chains, tensioners, guide rails and crankshaft sprocket.
Old 06-27-2019, 01:30 PM
Derf00
Gentleman's Relish
Derf00's Avatar
I don't see any mention of cam phasers in your list there...
Derf00 is offline
luqqzr
3.7L V6 Technical Discussions
10-01-2019 08:02 PM
ProjectLacey
03-25-2015 05:27 PM
FirstStang99GTCNV
02-02-2015 08:22 AM
cheesesticks2000
02-18-2012 05:54 PM
6mustang6
09-10-2005 09:46 PM
Quick Reply: 2006 Mustang GT engine rattle
