Cam moved during phaser replacement. HALP.
Hey Guys.
Hoping for help on this asap, as my brother is gonna lose his mind if I keep my car in his driveway for too long. I was trying to replace a cam phaser this past weekend. Followed all the instructions, or so I thought. As soon as I pulled the cam phaser, the cam jumped forward. I had marked it, so I know where it has to go to get back right. However, I couldn't rotate it enough to get there.
Any tips or tricks? I need to be able to rotate the passenger cam counterclockwise about 30-40 degrees. I can use a wrench and get it ALMOST there, but not quite.
Do I have to just bite the bullet and pull the front timing cover and redo all the timing?
PLZ HALP.
2005 Mustang GT 5-speed
PLZ HALP.
The cams stay in full advance when parked so it's likely at least two intake valves are coming into contact with a piston when you turn the cam anticlockwise.
90Mustangfan
Oct 6, 2005 11:17 PM
