need you for lock problem,,,
Old Dec 4, 2022 | 09:32 AM
fikok's Avatar
fikok
Unhappy need you for lock problem,,,
hi guys
my driver door wont unlock with the remote neither with the unlock button inside, it lock with the remote and both driver/passenger button
passenger door work just fine.
i tried both remote, i tried replace the door lock actuator but its the same...
any idea ? thank you a lot !!
can it be the sjb ?
if yes may i clean something or else ?
Old Dec 4, 2022 | 10:31 AM
fikok's Avatar
fikok
is there a driver door unlock relay ?
Old Dec 4, 2022 | 06:02 PM
HypromanGT's Avatar
HypromanGT
There is one in the SJB, apparently, although it seems like it's not a replaceable part?
https://iihs.net/fsm/?d=40&f=Power%20Door%20Locks.pdf
I'd check that box for water damage, corrosion, etc. These cars are prone to water leaks near/above that box.
Old Dec 4, 2022 | 11:52 PM
fikok's Avatar
fikok
Yes i will check for corrosion, and IF i have corrosion what should i do? I spray contact cleaner?
Old Dec 4, 2022 | 11:53 PM
fikok's Avatar
fikok
Sorry, dont know how to edit, but yes i had water leak, now solved
justaguy65
Apr 3, 2008 07:10 PM
stangnubie
Mar 23, 2008 08:43 PM
FastMustang06
May 7, 2007 11:26 PM
shelbsassy
Mar 26, 2007 03:53 PM
Silent Rain
Mar 6, 2007 04:54 AM
