Amp remote wire?
Old Nov 7, 2005 | 06:16 PM
RedAlertlb's Avatar
RedAlertlb
Default Amp remote wire?
Does anyone know what wire im supposed to use for the remote wire for a amp install on the stock headunit?
Old Nov 7, 2005 | 06:48 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Amp remote wire?
it's the 'on' switch for your Amp if you have one installed. Three basic power connections to any amp (+), (-), and Remote. When the remote lead has power from the head unit (when the head unit is turned on) it tells the amp to switch on.
Old Nov 7, 2005 | 07:34 PM
RedAlertlb's Avatar
RedAlertlb
no i mean where am i supposed connect the remote wire in the back of the stock headunit like which wire to splice
Old Nov 8, 2005 | 04:23 PM
StupidTodd's Avatar
StupidTodd
There isn't a place...
I'd suggest just tapping into any wire that was 'live' when the car was turned on, but not live when the car was turned off...
Just check the stock connections with a multimeter, you should have 2 hot wires... 1 is hot all the time, the other only when the car is turned on... use that one for your remote... or you could use a toggle switch, but if you forget to turn the toggle off, your amp stays on
Old Nov 9, 2005 | 11:02 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
An even easier location is to tap into a fuse in the fuse panel. Find one that is hot only when the ignition is on (such as radio, wipers, cruise, etc....) Sure this isn't a true turn on from the radio itself, but how OFTEN do you drive the car with the radio off anyway?! And even if you do - it doesn't hurt your amp to be on with the radio off.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
