Vacuum/Blower
Old Nov 11, 2005 | 01:08 AM
AmericanMuscle's Avatar
AmericanMuscle
Default Vacuum/Blower
Does anyone use a vacuum/blower combination to dry their car? If so, do you use it for the entire car.. or just the door jams, under the hood, crevices etc. And are there any negative aspects to blow drying your car like water spots or anything else...
And I feel stupid for asking this, but if you vacuum your car with a vacuum/blower combo and you then go to dry it with the blower.. wouldn't you theoretically just blow-out everything you sucked in (like in a shop-vac)? Essentially sand blasting your car? Or is there a seperate air bag for the blower?
What about this item..
http://autogeek.net/vacuumblowers.html
Old Nov 11, 2005 | 01:12 AM
FastBackDan's Avatar
FastBackDan
Default RE: Vacuum/Blower
Sometimes I blow off my car with the leaf blower. Everyone thinks I'm crazy, but I know I am
Old Nov 11, 2005 | 01:14 AM
AmericanMuscle
ORIGINAL: FastBackDan
Does it work just as good as hand drying, if not better? I was thinking about getting a leaf blower.. despite the fact that I don't have any trees lol.
Old Nov 11, 2005 | 10:14 AM
Dean Martin's Avatar
Dean Martin
I also use a leaf blower every time, after reading that tip somewhere. I still hand dry the whole car, but it sure helps force the water out of cracks and crevices so that you don't come back after an hour and see drips rolling down your car.
Old Nov 11, 2005 | 10:41 AM
Hambone's Avatar
Hambone
ORIGINAL: AmericanMuscle
The dirt/sand/etc. is "trapped" in the vacuum...it just uses the "exhaust" port to blow. This is what the filter is for--trapping the crud, but allowing air to suck through the filter, and OUT of the vacuum. Same principle as your house vacuum--it doesn't blow dirt all over the house, does it? (at least I hope not )
Old Nov 11, 2005 | 02:54 PM
chrisc's Avatar
chrisc
wow..leafblowers..you guys are crazy [8D]
Old Nov 11, 2005 | 04:03 PM
Stoenr's Avatar
Stoenr
I use the air compressors at work to blow mine off. The grills hold mad water on these cars.
I blew the temp lic plate right apart and off my car. Its like a semisealed paper plate.
Old Nov 11, 2005 | 04:09 PM
saud alzaabi's Avatar
saud alzaabi
Well i just use the dry cloth and just wipe the hell out of it..then i just switch on some music and open the doors/hood and trunk and just dry whats left over.
Old Nov 11, 2005 | 05:02 PM
Rider's Avatar
Rider
Yea, leafblower is great. I started using one on my motorsickle a few yeas ago, bikes have nooks and crannies all over. Now I use it on my Mustang, not all over but the grille, brakes and wheels, wipers, body gaps, etc. Follow up with a blade and then microfiber towel. I like it better than compressed air because it moves more air volume, won't blow stuff off the car, and won't spit oil.
Old Nov 11, 2005 | 07:09 PM
AmericanMuscle
Does anyone use it to dry the entire car? Any negative aspects to using it on the paint?
