gas tank
Old Nov 15, 2005 | 06:49 PM
Ginstang's Avatar
Ginstang
Default gas tank
Ok...I never had a problem with my gas tank with my V6..but the other day when I filled my GT up for the 1st time I set the nozzle to cut off on its own and when it stopped I did not try to put more in but started to release the nozzle out and gas poured all over my car..What is up with that?? Has this happened to anyone else?
Gin
[IMG]local://upfiles/21987/B3F19403E2624919A30AA0CF8E697BFC.jpg[/IMG]
Old Nov 15, 2005 | 06:52 PM
torch red's Avatar
torch red
Default RE: gas tank
i have read plenty of times on here about the problem, i always fill it half speed, i thing there is a TSB on the problem.
Old Nov 15, 2005 | 07:52 PM
bluesuede's Avatar
bluesuede
Just got my grey on grey 2006 on friday when I went to fill the 2nd tank of gas it bubbled over ,guess I'll fill it at half speed too.
Sean
Old Nov 16, 2005 | 05:58 PM
Ginstang's Avatar
Ginstang
ok..WHEN YA'LL SAY FILL IT HALF SPEED DO YOU MEAN LIKE PUSH THE NOZZLE JUST HALF WAY??? lol dO YOU STICK THE NOZZLE IN AS FAR AS IT WILL GO
ALSO TORCH RED WHAT IS TSB STAND FOR?
THANKS GIN
Old Nov 16, 2005 | 06:13 PM
VaporDude's Avatar
VaporDude
TSB = Tech Service Bulletin - They use them instead of a recall on minor problems just like this that doesn't affect a vast amount of cars. Put the nozzel in all the way, pull the handle half way so the gas doesn't into your car as fast.
BTW - I think your caps lock was on and you didn't notice it.
Old Nov 16, 2005 | 06:20 PM
Ginstang's Avatar
Ginstang
Thanks so much 05BlueGT...I will try that next time...Luckily when it happened i was going home for lunch so i washed the gasoline off of the car...
Ok now I know what TSB means..are they going to recall these back or do nothing about it?
Gin
Old Nov 16, 2005 | 06:42 PM
JJ_Stang's Avatar
JJ_Stang
I was under the impression that this was a problem with the 05's that had been resolved with the 06's, that being said I have had a problem filling tank twice, both at the same station same pump, other pumps at the same station are fine. I think it has to do with how fast the pump fills the tank, normally I only fill at half speed because of the problems I have read about, but that one particular pump I have to hold he handle and have to fill extremely slow and still get the overflow. When I bring it to the dealer for the rattle in the dash I am going to have them look at the tank as well.
Old Nov 16, 2005 | 07:10 PM
Ginstang's Avatar
Ginstang
jj Stang evidently that have not fixed the problem since mine and yours are 06's..I never had the problem on my 05...
gin
Old Nov 16, 2005 | 07:41 PM
VaporDude's Avatar
VaporDude
The original problem with the 05's was it took forever to get gas in the tank. This is a new problem that came up.
Old Nov 16, 2005 | 10:04 PM
Ginstang's Avatar
Ginstang
Sounds like Ford just reversed the problem....
Gin
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
mrappe
Sep 26, 2015 10:16 AM
