Trunk Release Sticks
Old Nov 18, 2005 | 02:41 AM
2k5conv's Avatar
2k5conv
Default Trunk Release Sticks
Is anyone having a problem with their trunk release sticking? Lately, it seems that I have to click it twice to get the trunk to pop up. The latch clicks each time but only after the second time will the trunk pop up. I tried cleaning the weatherstrip, thinking it might be sticking to the trunk, but that didn't help.
Also, this mainly happens when the trunk has been closed for a day or so. It's not repeatable each time, especially after just opening the trunk.
Old Nov 18, 2005 | 04:24 AM
SilverR1_04's Avatar
SilverR1_04
Default RE: Trunk Release Sticks
Mine did that once..... my Cougar use to do the same thing, like the spring wast losing it's push....
Old Nov 21, 2005 | 07:24 PM
Tik_Tok's Avatar
Tik_Tok
Mines starting to do that, figured I'd mention it to the service people next time it's in. I didn't pay for a warranty for nothing.
Old Nov 22, 2005 | 04:24 AM
Orion_240's Avatar
Orion_240
Mine is starting to act up. I push the button on the remote and it goes "click...clack" instead of just one simultaneous "click" sound.
Is there something that needs to be lubricated?
Old Nov 22, 2005 | 11:19 AM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Mine too.... seems the rubber gets "Sticky" with the cooler weather.
The trunk does "unlock".. you have to slip your fingers under the edge of the trunk and lift... you will hear the rubber peal as it releases itself.
A very find coating of silicone lube took care of it for me.
Old Nov 22, 2005 | 12:25 PM
StupidTodd's Avatar
StupidTodd
After removing my stock wing, my car started to have the trunk release problem as well.
I don't think it had anything to do with the wing removal, but happened about the same time. Maybe, since I don't have the wing to use as a handle, I notice it more now.
Anyhow, I've found that if I just push down slighly on the trunk and release, it pops the latch, and opens easily.
I'll have to try the silicone lube idea and see if that works for me or not.
Old Nov 22, 2005 | 02:18 PM
chrisc65's Avatar
chrisc65
< A very find coating of silicone lube took care of it for me>
Mine is sticking too. Hey Prof could you provide a picture/diagram(or be more specific) as to where you lubed it up?
This is frustrating as hell because my wife and kid both try to lift the hood by the wing and I know if this keeps up they are gonna tear it off.
Old Nov 22, 2005 | 04:31 PM
Professor Wizard
MF Moderator
No pictures needed really.
I took a can of Silicone Lube spray.... lightly sprayed my finger and spread it along the edge of the rubber seal that surrounds my trunk. Covers 2 bases at once... keeps the rubber from sticking to the trunk lid, and treats the rubber so it will last just a little longer.
Old Nov 22, 2005 | 05:14 PM
RedAlertlb's Avatar
RedAlertlb
yea mines does that sometimes, but you can still just reach under and pull it up its unlocked already. i found this out when i thought i popped the trunk and looked and it wasnt up...so i just go in the car and started driving and the trunk adgar thing came on.
Old Nov 22, 2005 | 10:21 PM
chrisc65's Avatar
chrisc65
ORIGINAL: Professor Wizard
My wife and son thank you for saving them from my wrath and most importantly, my disapointment! Thanks Prof!
