engine light on....
Old Dec 14, 2005 | 05:56 AM
DEEPBLUE's Avatar
DEEPBLUE
Default RE: engine light on....
this is what happened this morning
after 5 minute to started the can i have read Failsafe Engine Mode , i have turn off the key and i have restarted agian the car so after 10 minutes the engine light was on, i have read the followings trouble codes with a Predator
p0174 system too lean
p1000 Obd system Readiness test not complete
p2106 Throttle actuator control system-forced limited power
yesterday the codes were differents...
someones can halp me to understaind the right way?
thanks a lot
Old Dec 14, 2005 | 10:27 AM
Blankman's Avatar
Blankman
Your CAI is making your engine run lean without the proper tune for it.
Old Dec 14, 2005 | 10:45 AM
DEEPBLUE's Avatar
DEEPBLUE
AND WHAT CAN I DO BY MYSELF ??? LET ME KNOW !
Old Dec 14, 2005 | 12:21 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: DEEPBLUE
thanks a lot
Failsafe engine mode?? Wrong tune definitely. Don't run the car like that. It's meant to be used only to 'limp' home when there's a major problem, you will do engine or emmissions systems damage to your car that way.
I would e-mail predator and explain your situation to them, including the fact you are in ITALY. There is probably a different tune for the car that they must use in order to be compatible with european gases/additives. For now put the stock CAI back on and put the factory tune back in until you get a response and hopefully resolution from Predator.
Old Dec 14, 2005 | 01:20 PM
DEEPBLUE's Avatar
DEEPBLUE
thank you.
i have cancel the messgges by Predator now all goes on in the right way, i'm curious tomorrow morning.
i have set the 91 oct , because here we run with 98 oct but it's around 93/94 USA octane.
let me know asap what i will do .
thank so much for taking care of this problem.
ciao Giampaolo
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
Nov 5, 2015 04:18 PM
J.casone400
Aug 28, 2015 09:33 PM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
drumhedd2005
Aug 13, 2015 09:59 AM
