jack stand points
Old Dec 26, 2005 | 07:39 PM
351PONY's Avatar
351PONY
Default RE: Floor jack points
I'd be interested in seeing pics specifically showing the points being used with a floor jack. After looking under the car and not seeing any place where I'm comfortable using my floor jack I've resorted to using the standard scissors jack (aka the knuckle buster) in the notched areas indicated in the owners manual, or a buddies lift when the scissors jack isn't sufficient. I was told by Ford to not use the rear diffrential as a jacking point (although I have to say we've always used this as a jacking point on the classic 'Stangs).
Old Dec 26, 2005 | 07:42 PM
M's Avatar
M
Yea if anybody can get some pics up that would be great...i have been using ramps but im sure at some point that i will need to use the stands and i just want to see where everybody is with this.
Old Dec 26, 2005 | 08:44 PM
chevykiller's Avatar
chevykiller
I ♥ Acer
ORIGINAL: 351PONY
I'll be changing tires again on the 6th for the track. If no one has posted a pic by then, I'll post pics with the floorjack in this thread.
Old Dec 26, 2005 | 09:03 PM
M's Avatar
M
cool
Old Dec 26, 2005 | 09:57 PM
fin1's Avatar
fin1
Floor jack points:
Front: About 8" in, right behind the front wheels, you will see the end of the a-frame ("U" shaped steel with a lip)
Rear: Rear diferential
Old Dec 27, 2005 | 12:29 AM
tangtang's Avatar
tangtang
these pics should be idiotproof, so we can finally close this thread.
enlarge them and you will see the red arrows pointing to where to place the "jackhead".
here we go:
[IMG]local://upfiles/24317/33FD9ABF44F24F75BFED6E7AEEA9BFB1.jpg[/IMG]
[IMG]local://upfiles/24317/176DEFF78CF846B5933AE3C00D5BD56D.jpg[/IMG]
[IMG]local://upfiles/24317/046434FC5D244810B52904209929618E.jpg[/IMG]
[IMG]local://upfiles/24317/BAAAEFCA6603410880958EFBE33C9B61.jpg[/IMG]
[IMG]local://upfiles/24317/526AA3F0F1494BB89E15F2DD04365537.jpg[/IMG]
Old Dec 27, 2005 | 12:33 AM
tangtang's Avatar
tangtang
and one more
[IMG]local://upfiles/24317/BC27587E75C246EEBEDE684FA4AC2AC1.jpg[/IMG]
Old Dec 27, 2005 | 01:41 AM
M's Avatar
M
not to prolong this tang, but thats the points i use for my floor jack, so if thats where i have my floor jack... what i am looking for is where is the best place for my jack stands, not my floor jack
...or if thats the points you use for your jack stands, then where do you lift the car with you floor jack to be able to use those points for your jack stands
is that a confusing enough way to ask..haha
Old Dec 27, 2005 | 12:08 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
I'll keep my eye on this thread and post pics of mine with the jack AND jack stands in place when I get the rear facia back from the dealer. I dropped it off yesterday so hopefully I'll have it back in a week or so.
I'll also snap a few naked pics of the facia-less rear end, and on of the MOSTER 20's against an old '79 TRX wheel
Old Jan 2, 2006 | 08:18 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: Floor jack points - PICS ADDED
OK, installed my Pypes H pipe yesterday so I took the liberty to post the actuall jacked up pics. Keep in mind that the Saleen side skirts cover up the stock jack points, so you won't see the same points that were pic'd above. Hope this helps:
Rear Jack Point:
Rear Jack Stand Point:
Front Jack Point:
Front Jack Stand Point:
Overall jack-up:
Also for those that want to see a bare naked 'Stang
And if you're wondering - the off road H sounds pretty killer with the Saleen axel back system Very throaty, no major drone - just sounds like a performance car should
