Chaser/Sequential tailights
Old Jan 4, 2006 | 06:28 PM
FREAKO's Avatar
FREAKO
Default RE: Chaser/Sequential tailights
ok I see...its like a nano second of a difference...
Old Jan 4, 2006 | 09:52 PM
28HopUp's Avatar
28HopUp
MF Administrator
FREAKO Date 1/4/2006 4:28:11 PM
The difference is more pronounced with the brake lights. Both settings burn three bulbs per side when the brake is on (an increased safety feature over stock), but when you lift the brake pedal in the Sequential mode, all three bulbs turn off at once. In Chaser mode when you lift off the brake, the bulbs finish their strobing outward cycle.
Old Jan 4, 2006 | 11:01 PM
karlriggs's Avatar
karlriggs
I also installed the kit from Meter4it and although at first i was like.... wow, i thought this was supposed to be easy.... but once you got the tail lights out, it makes perfect sense from that point to the end. By the time your done, and if you do it right though, you will know all about the back of your car, (i.e. how to take out your back seats, etc) But the finished product is amazing.
Old Jan 5, 2006 | 09:59 PM
chris_l_usa's Avatar
chris_l_usa
do they void the ford warranty on the whole electrical system?
Old Jan 6, 2006 | 06:09 PM
karlriggs's Avatar
karlriggs
Nope, not unless they can prove that the modification caused the problem in question with the car. Since the tailights are really simple and don't interfere with anything I highly doubt they could prove that it caused any problems
Old Jan 7, 2006 | 11:33 PM
chris_l_usa
ORIGINAL: karlriggs
I don't know though. Dealers are pretty good at finding a way to give you the shaft. But i'm sure you already know that.[sm=headbang.gif]
kangavskittie
Mar 2, 2006 01:57 PM
kangavskittie
Jan 27, 2006 09:29 PM
28HopUp
May 13, 2005 01:23 AM
IWinULose
Apr 30, 2005 02:41 PM
mustang_montana
Feb 25, 2005 10:29 PM
