WS-6 vs. Mustang Gt
Old Jan 9, 2006 | 11:54 PM
chris_l_usa's Avatar
chris_l_usa
Default WS-6 vs. Mustang Gt
Guy i work with wants to bet me $500 in a 1/4 mile race. His WS-6 is completely stock, and my Mustang GT is completely stock. Do i stand a chance? Figured i'd get some input before i became poorer and had my ego smashed. Any input would be appreciated.
Old Jan 10, 2006 | 12:01 AM
GT Premi's Avatar
GT Premi
Default RE: WS-6 vs. Mustang Gt
From what I've read and seen, it would be a driver's race all the way. If you get the jump on him and can shift, you probably would hold the lead to the end. If he gets the lead on you, he will hold it to the end. Far too risky to do it. If you do, you'd better set the terms to best 3-of-5 or 4-of-6 or something.
Old Jan 10, 2006 | 12:03 AM
Truxtun's Avatar
Truxtun
I had a '98 T/A, and stock it should run about a 13.4 - 13.8 1/4 mile depending on auto/manual driver, etc... I could run 13.8's all day long with a stock T/A Automatic.
Old Jan 10, 2006 | 12:04 AM
chris_l_usa
one thing i do know about him is that he sucks at lauching his car off the line, when that is one of my strong points. So i might stand a chance. Your probably right about the 3 out of 5, just in case he gets lucky and gets a good launch.
Old Jan 10, 2006 | 12:09 AM
badtzmaru's Avatar
badtzmaru
What are the years on the WS-6 and your GT? I have an example on the WS6:
Standard Engine:
5.7-liter V8
Horsepower:
325 @ 5200 RPMS
Torque:
350 @ 4000 RPMS
City/Hwy:
18/26 MPG
2005 Mustang GT
Horsepower 300HP
If both of you are stock I would put my money on the ws6 but miracles do happen..........good luck.
Old Jan 10, 2006 | 12:19 AM
GGIII's Avatar
GGIII
WS6 from start to finish. You'd need at least a Tuner to keep up. Those LS1s are beasts all over the RPM range.
Old Jan 10, 2006 | 12:27 AM
chris_l_usa
ORIGINAL: badtzmaru
Standard Engine:
5.7-liter V8
Horsepower:
325 @ 5200 RPMS
Torque:
350 @ 4000 RPMS
City/Hwy:
18/26 MPG
2005 Mustang GT
Horsepower 300HP
Standard Engine:
5.7-liter V8
Horsepower:
325 @ 5200 RPMS
Torque:
350 @ 4000 RPMS
City/Hwy:
18/26 MPG
2005 Mustang GT
Horsepower 300HP
But you also have to consider that 300HP isn't accurate. Ford under rated it, just like they do for all of their engines.
Old Jan 10, 2006 | 12:29 AM
chris_l_usa
ORIGINAL: GGIII
Isn't the LS1 what the 04' GTOs had in them, and i've seen the 05' mustangs beat the 04' GTOs quite a few times. Is the WS6 just set up better than the 04' GTO?
Old Jan 10, 2006 | 12:33 AM
chris_l_usa
ORIGINAL: GGIII
What tuner do you recommend and how much $? Also can you save the stock programming into it so you can change it back to stock to bring the car in for warranty work? What are the performance increases with it?
Old Jan 10, 2006 | 01:38 AM
MHShockey30's Avatar
MHShockey30
Yes the 04 GTO's do have the LS1 in them. 350 hp. They are basically the same. Maybe a slight weight difference between the two. I would recommend the SCT X-Cal 2, its great and will run you about $380.00. Yes you can save your stock settings before bringing it in for warranty work. The performance increases vary depending on what mods you have done to your car. When you order the tuner they will ask for a list of mods that you have done to your car and create you 3 tunes based upon your mods.
