RUST
Old Jan 20, 2006 | 05:03 PM
The Ghost's Avatar
The Ghost
Default RE: RUST
Yea, I just put springs on mine and was kind of blown away at the amount of rust. Pull a wheel and look at the hats on the disk brakes as well as any clips that hold pieces in place. Seems that if it is hidden from view it is rust prone. I was thinking about POR15 on the rear end. Prof Wizrd, what did you use?
Old Jan 20, 2006 | 05:13 PM
LesteR723's Avatar
LesteR723
Default RE: RUST
i went with ziebart through my dealer... no rust
Old Jan 20, 2006 | 07:31 PM
ford4v429's Avatar
ford4v429
Default RE: RUST
I tore mine apart to undercoat...slow going, but found some interesting areas- quite a few pics in this thread:
http://forums.bradbarnett.net/index....dpost&p=613967
Old Jan 20, 2006 | 07:37 PM
SwtPnyChick's Avatar
SwtPnyChick
Lady Luck
Default RE: RUST
Hmmm....this brings up an insteresting fact. In Las Vegas that offer a Desert Package (all dealerships) which give the paint a protectant from the severe heat. Can't they do the same for rust/cold?
Old Jan 21, 2006 | 12:12 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: RUST
Curious about the Ziebart undercoating - do they spray EVERYTHING (such as exhuast, suspension, tranny, oil pan etc) or only the actual under carriage? I would like to see my undercarraige, drive shaft and rear axel done in that nice looking black under coating - but not my suspension and other mentioned parts. So will the take the time to the proper masking, and what is a typical cost of this?
Old Jan 21, 2006 | 12:24 PM
Stoenr's Avatar
Stoenr
Default RE: RUST
ughh, I know what you are feeling. But no one really ever sees that part of the car anyway.
I should have painted mine right away
10 days after having still looked good
Old Jan 21, 2006 | 01:48 PM
ford4v429's Avatar
ford4v429
Default RE: RUST
cant undercoat the driveshaft- balance...suggest etch rust, then just spraypaint it.
Axle- just etch/brush on POR-15, it will last forever-normal spraypaint will likely get chipped up...could always spray areas back in corners(like around control arm bushings if you dont want to unbolt), that are too hard to reach using like a wd-40 straw, then just let it drip off/wipe excess and brush some por15 on everything else. If using metalprep/'ospho' phosphoric acid to etch, just rinse really really well, and again to make sure its neutralized- then if its fully dry the por15 will basically NEVER come off.
Its supposed to get nice out tomorrow, hope to get my other fender back on today- going thru mustang withdrawl
Old Jan 21, 2006 | 06:57 PM
viking396's Avatar
viking396
Default RE: RUST
ORIGINAL: sdmahr
Ziebart did mine....underneath, between panels, everywhere ! !
Holy crap, they're still in business?
Old Jan 22, 2006 | 03:02 AM
snogoldi's Avatar
snogoldi
Default RE: RUST
https://mustangforums.com/fb.asp?m=955019
On post#16 what is that Contraption Between the mufflers ?
Old Jan 22, 2006 | 03:11 AM
Stoenr's Avatar
Stoenr
Default RE: RUST
i believe its a shield/support for part of the cars evap system.
