Weight differences?
Where should I look to find the weights of 05 V6 and V8 Stangs. The old SVO 2.3 turbos had enough weight savings to accelerate close to 5.0L and out handle in corners. I tried SCCA racing where they use a few more corners than most. If there is a big enough difference between V6 and V8s I might have another option.
[sm=smiley20.gif] [sm=smiley21.gif]
Curb weight (according to Car & Driver)
V6: 3444 lbs
GT: 3523 lbs
Each webpage also lists speed stats.
V6: 3444 lbs
GT: 3523 lbs
I got the following stats from Cars.com and a pamphlet for the new mustangs I received from the dealership:
V6 mustang 05/06: 3,351 lbs curb weight
V8 mustang 05/06: 3,483 lbs curb weight
Both numbers are for the coupe model. I don't know which set of stats is correct....but I figured I'd pass these along since they turned up identical in two different sources.
mungodrums
Suspension
Sep 24, 2015 10:12 PM
