Need help finding a new hood.
I have a trufiber hood. you DO NOT need hood pins. The only reason that is there is so they are not liable if something happens. You will see a lot of people with aftermarket hoods without them. Just adjust the bump stops accordingly. Personally I love that hood, it really complements the aggressiveness of the new front ends!
Oh, and pics?
So the hood came in last week and the shop is putting it on now and they tell me there aren't cutouts for the wiper fluid nozzles. Also, they tell me it didn't come with a "Reinforced Metal Latch & Hinge Plate". WTF?
From their site:
All TRUFIBER aerodynamic parts and auto accessories give you the best in show and off-road performance. All of our fiberglass and carbon fiber products are designed with the driver and show car enthusiast in mind. Each product contains a variety of features that give your vehicle a true advantage when facing any competitor both in the show or on the trail. Each product is an exact fit to your model and body style by year and installs easily and securely using OEM hardware and manufacturer accessories. For safety purposes hood pins are required for ALL aftermarket hoods.
*Fully Functional Heat Extractor
*Hot Air Exits From Two Open Rear Heat Extractor Vents
*Show Quality Finished
*Hand Laid Fiberglass
*Smooth Gel Coat Finished Both on Top and Bottom Sides
*Reinforced Metal Latch & Hinge Plate For Additional Safety
*Integrated Stainless Mesh Grille
*Pre-Drilled Prop Hole
*Will Not Work With Hood Shocks
*Direct Bolt-on Using OEM Hardware
*Approximate Weight: 40 Pounds
From their site:
EDIT: Just talked to him again and he said there are little square cutouts on the factory hood that they mount to, but they're underneath or some ****. I obviously don't have my car so I have no idea what he's talking about.
