Headlight Recommendations?
Old Apr 19, 2012 | 10:38 AM
majik755's Avatar
majik755
Default Headlight Recommendations?
I want to swap out my standard halogen headlights for a newer headlight which will blend more with a darker scheme front end. I can get black instead of chrome housings and some even offer smoked, but I don't want any less light output than the standard light which is pretty bad anyway, hopefully I can get it a bit brighter but want to stick to white lights not blueish. Confused between, halogen, projectors, HID, LEDs etc. Any recommendations on types/brand? This is a DD so they must be street legal. Thanks...
Old Apr 19, 2012 | 10:45 AM
jsimmonstx's Avatar
jsimmonstx
You could try one of the heavy duty pigtails that uses larger wire, and that allows more current to go to the existing assemblies, and then pair that up with brighter bulbs. That's how I'm gonna try it.
Old Apr 19, 2012 | 12:25 PM
BKamp613's Avatar
BKamp613
Retrofit if at all possible. I had the smoked raxiom projectors and even with HIDs the output was not good.
My housings were painted black so they appear dark, but doesn't diminish output at all.
My write-up:
https://mustangforums.com/forum/2010...ofit-hids.html
Excerpt:
For comparison, retrofit is by far the best option (aside from factory HID). HIDs installed in factory reflector housings cause glare, and throw light upwards. It's not very usable. You get the "look" of HID, but none of the cut-off and color flicker you get with projectors.
Raxioms are a good step up from HIDs in halogen reflectors. I had the smoked lens version, which definitely reduced light output. IMO, HIDs are a necessity for smoked Raxioms. The light the included halogen bulbs provide is on par (if not slightly worse) than standard reflectors + halogens. Even with HIDs, the Raxiom projectors don't put out enough light, especially on foggy/rainy nights. You get a decent beam cut-off, but it's not very straight, along with minimal color band.
Retrofit is the best choice. There is a sharp beam cut-off line, with a great color band and wide beam pattern. The 5000k bulbs I'm running provide more light (at least 25%) than Raxioms with 4300k bulbs. Remember, the higher the kelvin, the lower the lumens. So even with a lower lumen count, the retrofits put out more usable light than Raxioms with a higher lumen count bulb. This is due to the better quality Morimoto projectors and clear outer lens.
If you're going to spend the $ on projectors, skip the Raxioms and do a Retrofit. The extra cost means a world of difference in performance.
Old Apr 19, 2012 | 12:41 PM
majik755's Avatar
majik755
Default Thanks - Great Write Up
Thanks for your feedback and the writeup included was great, answered many of my questions. Guess I should have searched first and would have seen this, wasnt even thinking about the headlights until today so probably read right past it when it was originally posted.
My write-up:
Excerpt:
Old Apr 19, 2012 | 12:52 PM
BKamp613's Avatar
BKamp613
No problem. The cool thing about retros is its entirely up to you how much you want to spend.
Depends if you can go headlight-less for a couples weeks, or have a spare set. There are clear lens raxiom-like (different vendor) headlights out there. I had two sets, but there were imperfections on the projectors. Returned them. It's about $50-?? more for retrofits, so the aftermarket ones aren't worth it IMO.
Old Apr 19, 2012 | 04:11 PM
majik755's Avatar
majik755
Yes, definitely looks like retrofit is the way to go. Hopefully StockD15b or someone else is still out there willing to do the mod, don't trust myself on anything like that.
Old Apr 22, 2012 | 11:29 AM
Wil's Avatar
Wil
Can you post some pictures of them on and just the amber lights on?
Old Apr 23, 2012 | 08:33 AM
BKamp613's Avatar
BKamp613
It rained all day yesterday, so I haven't had a chance to take pics. I'll upload some when I get home from work.
Old Apr 23, 2012 | 02:29 PM
bigD1515's Avatar
bigD1515
Subscribing I wanna see this Looking into retrofits..
Old Apr 23, 2012 | 06:07 PM
BKamp613's Avatar
BKamp613
Some after dinner shots (iPhone 4):
Weather still kinda sucks so I didn't take it anywhere cool to take pics. The last shot shows the very edge of the color band. The bulbs are 5000k, but the color varies depending on angle. These are very white at night:
Old pic (the trees in the back behind the traschcan are about 50ft away. I could also aim them up a little, but on the road they're perfect)
