Speed up sequential lights
Old Aug 26, 2012 | 11:10 AM
Wil's Avatar
Wil
Default Speed up sequential lights
Whats up guys, does anyone know if theres a way to speed up 2010+ sequential lights? I drove past a 2005-2009 stang with sequential lights that just looked amazing. It looked more fluid then the 2010+ style, I loved it.
Old Aug 26, 2012 | 06:10 PM
bigD1515's Avatar
bigD1515
Yeah I honestly like the way the 05-09's look. And when they brake, it's different then ours too xD I think the only way is to get a similar setup to what they have... I got no input really!
Old Aug 26, 2012 | 06:18 PM
AzPete's Avatar
AzPete
Factory is slower than after market.....there is your difference plus brake differences. I don't even think anyone makes one to fit the 10+ cars. It is most likely controlled by the computer where the after market units have the controller built into the wiring.
Old Aug 26, 2012 | 10:20 PM
Wil's Avatar
Wil
That sucks,if it is computer driven, couldn't a tuner speed it up? Guess I'm stuck with stock envying the 05-09 stangs.
Old Aug 26, 2012 | 10:42 PM
07BLACKGT's Avatar
07BLACKGT
Man you guys are weird. The 10+'s looking so good and crisp is the reason I haven't bought sequentials lol.
Old Aug 26, 2012 | 11:03 PM
wayne613's Avatar
wayne613
^^Agree. I like them better than mine..
http://iihs.net/fsm/?dir=1017&viewfi...20Lighting.pdf
When the multifunction switch is in the LH or RH TURN POSITION, the SJB turns the appropriate front turn lamps on/off and the BCM-B sequentially flashes the corresponding rear lamps beginning with the inboard lamp and ending with the outboard lamp.
..Nope. CAN-BUS, so technically someone "could" make the encrypted write for a tuner(or had the VCM/IDS tool with appropriate software) if it was in fact adjustable, but I'm pretty sure it's on a set timer circuit. It's just getting the CAN-BUS signal to fire off the timer circuit(s) in the BCM-B for either side.
http://iihs.net/fsm/?dir=710&viewfil...rd%20Lamps.pdf
Old Aug 27, 2012 | 09:05 AM
bones302's Avatar
bones302
strange thread...when I see 05-09's with sequentials, it's obvious to me they are aftermarket because they look a bit choppy.
you may want to check the lubricating fluid levels on your stock taillights. they might be low.
Old Aug 27, 2012 | 09:29 AM
5bites's Avatar
5bites
Don't LED's usually speed up blinkers?
Old Aug 27, 2012 | 10:45 AM
wayne613's Avatar
wayne613
For newer cars such as ours, and even the new edges I believe, but only because it's detecting a problem since the controller (SJB or BCM) is looking for draw on the line to tell if the bulb has gone out or not.
When it does this super-fast flash, it's not functioning correctly if at all, it's doing this to let you know there's an issue, nothing more. Which is why all of the after-market ones sold either have some resistance circuit built into it, or you need to buy one for it to function right.
Old Aug 27, 2012 | 08:14 PM
iamgone's Avatar
iamgone
Do you use synthetic or conventional lube in your taillights?
