Speed up sequential lights
Old Aug 27, 2012 | 11:55 PM
07BLACKGT's Avatar
07BLACKGT
Run some Sea Foam through them.
Old Aug 28, 2012 | 08:27 AM
5bites's Avatar
5bites
Originally Posted by wayne613
For newer cars such as ours, and even the new edges I believe, but only because it's detecting a problem since the controller (SJB or BCM) is looking for draw on the line to tell if the bulb has gone out or not.
When it does this super-fast flash, it's not functioning correctly if at all, it's doing this to let you know there's an issue, nothing more. Which is why all of the after-market ones sold either have some resistance circuit built into it, or you need to buy one for it to function right.
Thanks for the explanation Wayne. That's kinda along the lines of what I was thinking. I suppose if it doesn't hurt anything and that's what he was after he could try it.
Old Aug 28, 2012 | 10:19 AM
RichieCal's Avatar
RichieCal
This is funny because there was a post about a month ago about us 05-09 owners trying to slow down the sequence like you 10-13 owners LOL...I know this doesn't help you, but scott drake makes one for 05-09 with different settings where as you can have a slow sequence or a faster sequence. This is the one I have
Old Aug 28, 2012 | 10:45 AM
wayne613's Avatar
wayne613
Kinda like busting the windshield because you have a bug on it...
Perhaps you missed that part, "it's not functioning correctly if at all", the SJB, or in this case the BCM-B will likely cut power to any it doesn't sense the correct draw from. See a few of the problem threads for these installs(on 1st gen S197s)..
McLeary
Mar 14, 2016 07:50 PM
musnicki
Sep 23, 2015 07:11 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
amandahchase
Sep 3, 2015 10:09 AM
