3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Brake question
Old Jan 1, 2021 | 02:43 PM
Logan541's Avatar
Logan541
Default Brake question
Quick question guys been looking for an answer and can find a real answer is there a difference in the brakes (Calipers and rotors) between the 2014 v6 base and the 2014 (or any suitable year) GT? or any other suspension parts. sway bars, control arms etc.
Thank you in Advance
Old Jan 1, 2021 | 03:46 PM
JimC's Avatar
Super Moderator
The GT has a bigger rotor on the front so a bigger bracket for the caliper to move it out further.
Some of the 2014 GT's have performance package 6 pot front brakes also (Brembo look).
Rear brakes are the same for GT and V6. The only difference will be for performance packages.
Old Jan 1, 2021 | 03:54 PM
Logan541's Avatar
Logan541
What are the brake differences (caliper rotor front and rear) between the 2014 v6 base model and the GT?
Thanks
Old Jan 1, 2021 | 04:37 PM
JimC's Avatar
Super Moderator
Please don't post the same thing multiple times across the forum. Post it once in the proper forum.
Old Jan 1, 2021 | 05:14 PM
Logan541's Avatar
Logan541
Thank you. So if I wanted to upgrade I would just need the bracket an rotor but not the caliper correct? Thanks in advance
Old Jan 1, 2021 | 07:08 PM
JimC's Avatar
Super Moderator
Correct, you need the bracket and rotor and remove the bracket from your current caliper.
There is a write up or two because a lot of us did it on the 2005-10 S197 V6.
kevanstone
Florida Regional Chapter
Dec 2, 2011 07:33 PM
mitzutuner
Jul 22, 2008 04:00 PM
racing96gt
Oct 22, 2007 08:50 AM
mikeg
Jan 31, 2007 10:42 PM
